THE PROJECT: GrimReaper 2
Old Jul 30, 2008 | 01:02 PM
DJdemon6696's Avatar
DJdemon6696
the truck:
originally with an 4 speed manual ( yes strange 4 speed)
and an L6 but the L6 is coming out..
The Engine:
Gt 5.0 Gt40 heads and intake out of an explorer 96-97
BRAND NEW :
ohh and whats the best thing to do witht his engine? buy an mustang harnas or explorer harnas and with ECU.. and buy the intake plenum and trottle body and injectors and run it fuel injection? or make it carbed? and i only wanna do a cam swap .. wich cam will run best with this engine i was thinking this cam but it has to be MAF or carbed
COMP Cams 35-414-3 - COMP Cams Magnum Hydraulic Camshafts - summitracing.com
Old Jul 30, 2008 | 01:03 PM
DJdemon6696
hey guys will this work? the injectors and harnass and MAF setup ? tell me now i got to buy it now other wise i may lost my chance. thanks.!
eBay Motors: Mustang 5.0 Computer Mass Air Harness A9L A9M V8 Conv (item 160264938642 end time Aug-03-08 07:02:57 PDT)
Old Jul 30, 2008 | 01:09 PM
Conanski's Avatar
Conanski
How much they askin?
The motor alone is worth some coin, and all it really needs is 1.7 rockers, the stock cam is pretty good for a truck application.
I't would already be in my garage.. if I were the one stumbling across that and the price was reasonable.
Old Jul 30, 2008 | 01:21 PM
Conanski's Avatar
Conanski
The mustang harness won't fit a truck well at all, you'll have to disassemble it and re-arrange everythign so the computer can go in the truck location on the drivers side. But if you use a truck harness you'll have to repin a bunch of stuff and remove everything else you don't need.. like tranny controls. There's no free lunch, but this is the way to go IMO, buy some serviced injectors and a truck fuel rail off ebay or from a scrap yard, get the Stang ECU and MAF meter, and you're well on your way.
Old Jul 30, 2008 | 01:44 PM
DJdemon6696
lol the motor is already at my house its mine bought itfor 1300 $
can you help me find the right harnass and ecu for it? on ebay ? thanks conaski
Old Jul 30, 2008 | 03:40 PM
Jason Lewis's Avatar
Jason Lewis
I'm glad to see another "Flareside" getting some loving !!
I would get some Ford Motorsport Vale Covers For the 5.0L it would look sweet !
Old Jul 30, 2008 | 03:53 PM
EPNCSU2006's Avatar
EPNCSU2006
Are those the regular GT40 heads, or are they the -P heads? I agree with Paul, having a mustang harness on-hand for a MAF conversion is the way to go. I modified the truck harness, sourcing the missing pieces from the mustang harness. I consolidated the mustang injector harness from the two 10-pin plugs down to a single 10-pin and just grafted the wiring from injectors to computer into the truck harness.
Old Jul 30, 2008 | 04:02 PM
DJdemon6696
GT regular.. GTP is on the head marked as GTP this is just GT
so if i start buy buying this setup i can use it?
it has the ECU, fuel rail, that i need.. and then i will buy a truck harnass and integrade the MAF into it right?
Old Jul 30, 2008 | 06:53 PM
EPNCSU2006's Avatar
EPNCSU2006
I thought those looked like the standard plug angles.
I did the conversion on my 87 and the wiring is a lot different than your 92. You'll have to be picky about the truck wiring harness you find because I'm thinking that the harnesses changed in 92 and there were several variations between 92 and 95. Since your 92 is a stick shift, that makes it slightly easier since you may be able to use an automatic harness and take out the transmission wiring. That's about all I know, though, so you'll have to research on your own.
That ebay link looks like it has just about everything you need to get the explorer motor where it will run in the truck and the price isn't too bad at this point either. You may need to find a truck fuel rail because the location of the fuel line disconnects are in different places on the mustang fuel rail.
Old Jul 30, 2008 | 07:59 PM
DJdemon6696
ok ill buy that harnass tomorrow... and i have a friend that has an fuel rail so its ok.. thanks..
Old Aug 6, 2008 | 12:11 AM
DJdemon6696
sup i got some new pics and better pics of the truck
the body overall is good the only rust its got its on the rear window frame
and a little under the doors overall its good
the owner didnt know what he was talking about actually the truck is an 93 not an 92 like he said.. it has the complete harnass but of an l6 engine.. the l6 even has headers and an mazda 5speed gearbox.. any one interested? make me an offer .. complete engine with harnas and ECU PM me
i will use a complete stang harnass and build an computer box on the passenger,since the stang harnass ecu is on the passenger side..
, side and i wont mess with the harnass just chek for bad wires and install..
here are some pics...
Rear window rust
Old Aug 6, 2008 | 12:12 AM
DJdemon6696
ok i just found a C6 to put in my new truck.. i need some c6 knowledge
what converter should i use? for daily driver and a bit of performance?
and is this enough to get a good shift kit from a c6 ?
B&M 40228 - B&M Transpak Kits - summitracing.com
Old Aug 6, 2008 | 02:25 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
what are building here? a mudder truck or street truck? that engine looks like alot of fun once you get her running
I thought it had a 4 speed. was wondering how a 80's tranny got into 92+ truck. and I'm pretty sure all the 300's came with a header. got pics
sorry man, that mazda 5 speed is a POS. the F-250 5 speed is more desireable. you tried posting it on Craiglist yet? as long as the 1-2 and 2-3 synchro's are decent, you might $200 for the tranny. problem is those synchros destruct fairly quickly if you use the truck as a truck
Old Aug 6, 2008 | 09:02 AM
DJdemon6696
im building a street truck that flareside is a 2wd
yeah i was wrong i didnt see the shifter good it has a 5 speed tranny..
you can see part of the headers here
http://i198.photobucket.com/albums/a...6/IMG_0076.jpg
Old Aug 6, 2008 | 08:24 PM
Dustin1690's Avatar
Dustin1690
Looks like a good project congrats
