Power window on 99 F150
Old 09-18-2002, 10:43 AM
jeffs3's Avatar
jeffs3
jeffs3 is offline
I have a 99 F150 with power windows. The driver side window won't roll up. I removed the door panel and can't figure out a way to get to the motor. Has anyone replaced one of these motors? Do I need to replace this motor?
Thank you for your help.
Old 09-18-2002, 11:43 AM
kioolt's Avatar
kioolt
kioolt is offline
Generally to remove a power window motor you need to drill three holes in the door. The location for drilling these holes is marked with three indentations. You drill the holes and insert a socket to remove the screws.
Old 09-18-2002, 12:38 PM
jeffs3's Avatar
jeffs3
jeffs3 is offline
Thanks for the tip. I ended up figuring out that my problem was a bad switch. I replaced it for $80 and window works fine.
Old 09-18-2002, 09:13 PM
CACWBY's Avatar
CACWBY
CACWBY is offline
usedtoolman
05-30-2018 06:21 AM
KiwiFord
01-27-2010 12:12 AM
JohnT
05-12-2006 08:15 PM
johnny o
1997 - 2003 F150
11-09-2005 12:23 AM
shotgunner426
10-03-2003 04:06 PM
Quick Reply: Power window on 99 F150
