Sponsored by: Auxito
Installed Trans Temp
Old Jul 30, 2008 | 11:32 AM
BEAL73's Avatar
BEAL73
I am going to pull my 25' TT approx 6,000 pounds. I have an 01 SCAB with an updated heavy duty 4r70w w/towing package.
I installed a B&M trans temp guage on the output line of the tranny. So far I am seeing 150 on normal driving with empty bed and without towing. I can get it to around 175 in aggressive driving/shifts and it's been above 90 outside all this week. I have a larger cooler and bypassed the radiator cooler. Does those temps seem normal?
Old Jul 30, 2008 | 06:01 PM
Bluegrass 7's Avatar
Bluegrass 7
So far yes the temps are normal but expect to see the temp climb to over 200 with the trailer pulling a hill.
That is because the sensor is right on the output of the converter where the temps are the highest from fluid shear.
Don't worry about the temp unless it runs over 250 for extended time intervals then you have to be concerned about changing the fluid much more ofter due to breakdown..
Your gross combined weight is in the 11,000 lb + range so expect the fluid to heat up pretty good.
I have a fan cooled cooler that is set to come on at 185.
This helps cool at low road speeds as well as cools the engine bay at shut down. Usually runs about 5 to 8 minutes after shut down depending on the outside temp.
Good luck.
Old Jul 30, 2008 | 06:45 PM
Bobby82490's Avatar
Bobby82490
Thats pretty normal.. i get about 160 degrees while normal driving, outside temp 95+.
Old Jul 31, 2008 | 10:15 AM
BEAL73's Avatar
BEAL73
Thanks for the replies. Glad to know I am on the right track.
I was just at the recycler last week and the truck weighs 5,060 lbs. empty. I cant wait to go back there with 1,000 lbs of junk in the bed to see how it heats up. There is a long hill to get there and I was always curious to see what the tranny is doing. Since I put alot of work into it, the guage is a must have.
