That Sucker
Old Jul 30, 2008 | 09:55 AM
mueckster's Avatar
mueckster
That Sucker
For those of you interested in doing the HPOP oil change, I have posted pictures in my gallery 2001 Ford F250 4x4 - That Sucker of the oil evacuator (aka That Sucker), that I used to remove the HPOP oil. That Sucker uses the truck's vacuum pump to provide the vaccum to operate the jar and pull out the oil. Just turn the key to the "on" position after the hose connections are made. I plan on using That Sucker for removing other fluids, as well. Such as, it could be used for oil and fuel removal from the cylinders at an Injector change or removing P/S fluid.
Old Jul 30, 2008 | 10:01 AM
superduty4x4's Avatar
superduty4x4
Great idea, and great job on the photos/explanation. Repped ya for your help.
Old Jul 30, 2008 | 10:02 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Cool deal Roland, we should have a little more pic and info once we do mine. Glad you started a new thread on this.
Old Jul 30, 2008 | 10:09 AM
mueckster's Avatar
mueckster
Thanks Chase.
Thanks Rick,
We will build the "revised version" for yours. It will have simpler connections for the tubing as described in the album. Also, thanks for your "tech support" on this proect.
Old Jul 30, 2008 | 10:11 AM
miller_feed
Originally Posted by mueckster
Thanks Chase.
Thanks Rick,
We will build the "revised version for yours. It will have simpler connections for the tubing as described in the album. Also, thanks for your "tech support" on this proect.
Old Jul 30, 2008 | 10:15 AM
superduty4x4
Eagerly awaiting the "revised version" photos- I'm going to build two and keep one in the truck for those unexpected situations.
Old Jul 30, 2008 | 10:25 AM
F250_'s Avatar
F250_
Great concept... I will certainly put one together for my own use, like when I have to remove some brake fluid before changing brake pads. I have to spread it around though, before I can give you the points you deserve for posting this.
Old Jul 30, 2008 | 11:04 AM
03_PSD's Avatar
03_PSD
wow, thats cool. reps comming your way!!
Old Jul 30, 2008 | 11:15 AM
HKusp's Avatar
HKusp
So the fitting on the truck is that 1/4" and thats why you had to use the 1/4" to 3/16" adapter?
Old Jul 30, 2008 | 11:31 AM
mueckster's Avatar
mueckster
The connector on the truck is 3/16" and the vinyl tubing, I used, is 1/4 ID.https://www.ford-trucks.com/user_gal...194595&width=0 The plastic connector is in the vacuum hose end on the truck.
Old Jul 30, 2008 | 12:22 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Good job Roland. I promise I won't tell em it's a 'modified' Bohunk water pipe!!
Old Jul 30, 2008 | 12:35 PM
miller_feed
The tube don't go all the way to the bottom.
Old Jul 30, 2008 | 12:39 PM
guitarpicr's Avatar
guitarpicr
Great job Roland - Reps Sent. Thanks
Old Jul 30, 2008 | 12:40 PM
joegebff's Avatar
joegebff
Old Jul 30, 2008 | 12:55 PM
HKusp's Avatar
HKusp
Is that of the "oily bohunk" type?
