Big!!!! Electrical Question.
Old Sep 11, 2002 | 10:18 AM
airrds1's Avatar
airrds1
Post Big!!!! Electrical Question.
I need some input on what electrical system provider any of you folks
have used/or entend to use in your project. I'm trying to make the best decision here, about what wiring kit I want to use.
Need Opinions. Thanks Folks.
Old Sep 11, 2002 | 03:24 PM
Mil1ion's Avatar
Mil1ion
Most people I know have found a used harness out of a wrecked truck.
Other's have bought a painless wiring system ,but I have heard it isn't that painless.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 11, 2002 | 04:11 PM
a63unibody's Avatar
a63unibody
I'm in the process of wiring my 63, I'm using a harness from a 79 LTD,
Robert
Old Sep 11, 2002 | 05:37 PM
airrds1's Avatar
airrds1
That thought has also crossed my mind about use a late model harness,
From a Mustang. Might that work!! Using 85/89 Mustang Column.
That could save a ton of money going that route.
Old Sep 13, 2002 | 12:32 AM
krazdndenver's Avatar
krazdndenver
For mine I made the harness for the computer. Took some time but the wire was free (work) But I just ordered a fuse block from painless, I think this will make the rest of the electrical work a bit easier. There prodects are expensive but make things go together easier.
Robert
72 F-100 Ranger XLT W/ 86 5.0L W/AOD
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
Old Sep 19, 2002 | 09:10 PM
41Clay's Avatar
41Clay
I did mine from scratch, added each item one at a time starting with what it needs to run and what I want. I would go with EZ wiring(?), they have the easiest to do setup and isn't as exspencive as painless. I was on a budget and wanted two seperate circuts so I used two small Buss fuse blocks and did some abnormal wiring. It took some research and planning, mainly because of the '67 Galaxie colum, but now I know how everything works and it only cost me about $50. Only trouble came from a Radioshack relay.
Old Sep 19, 2002 | 09:24 PM
41Clay's Avatar
41Clay
