Duraspark ignition modules
Old Sep 23, 2002 | 11:44 PM
FordmanRon's Avatar
FordmanRon
I'm converting from a points to electronic ignition.....I pulled up some info on the net on wiring it up and everybody seems to be saying to use the module with the blue grommet....why? what is the difference other then the wire connectors? is one better then other? .....also can I use the original points coil with screw connectors or do I have to switch to the Duraspark model with horseshoe connector?
Old Sep 24, 2002 | 01:04 PM
gasman6674's Avatar
gasman6674
I am a little rusty but I believe the blue gommet module was more resistant to heat failure. Sorry I cant be more positive went to school on this in the late 70's and have not used it since.
I would use the horse shoe it will make a neater install
Regards
Gasman
Old Sep 24, 2002 | 04:49 PM
Franklin2's Avatar
Franklin2
I know some of the other color modules had different features as far as spark retards and other stuff used for emissions. The blue one is a simple straightforward spark box.
Old Sep 24, 2002 | 10:40 PM
FordmanRon's Avatar
FordmanRon
Thanks for the info......FordmanRon
Old Sep 25, 2002 | 12:09 AM
HD61cuin's Avatar
HD61cuin
KsCop
Mar 6, 2014 10:42 AM
QwkFox
Electrical Systems/Wiring
Dec 25, 2013 09:27 PM
pidaster
Aug 20, 2011 07:38 AM
Woodsman_30350
Oct 2, 2008 10:07 PM
Alvin in AZ
Aug 28, 2008 09:16 PM
