Sponsored by: Auxito
97 4.2 towing question
Old Jul 29, 2008 | 06:56 AM
supertruck's Avatar
supertruck
I have a chance to buy a mint 97 shortbox 4x4 regular cab....standard with the 4.2...I have a 5000 pound travel trailer when fully loaded..will this truck/egine do the trick or should I pass on it...I figured being a standard,it might have a bit more lower gearing for better pulling.....I have equalizer hitch and bars.....the farthest I would tow ever would be around 300 miles to the inlaws..not real hilly or mountainous
Thanks for any advice
Bob
Old Jul 29, 2008 | 11:21 AM
Bobby82490's Avatar
Bobby82490
I personally wouldn't use that truck to tow 5000lbs.. esp with the manual that comes with these trucks...they are a weak transmission.
A short bed regular cab, with the 4.2 and a manual tranny is probably the worst combonation for towing anything heavy in these trucks. The only thing that would make it worse is if the truck had the 3.08 gear ratio.
For that kind of weight i would recommend a f-150 with at least the 4.6 and a auto tranny.
Old Jul 29, 2008 | 12:39 PM
MaximaDogg's Avatar
MaximaDogg
well spoken I second that
Old Jul 29, 2008 | 06:58 PM
AzBlueWolf's Avatar
AzBlueWolf
are all the 5 speeds junk?
My neighbor had a 94 f250, I6 with 5 speed,with camper in the back and pulling a small boat he got 19 mpg in the mountains of New Hampster and Maine
Old Jul 29, 2008 | 07:09 PM
triton_2002's Avatar
triton_2002
I had a 2000 4.2 regular cab with the 5 speed. It was a fun truck around town, but wouldn't use it for any kind of serious towing. I loaded it once with 1/2 yard (one scoop of a small frontloader) of gravel and sand, and the front end was up in the air and really hard to drive (only drove it about 5 miles with it loaded).
Old Jul 29, 2008 | 07:10 PM
Bobby82490's Avatar
Bobby82490
No i dont think the older trucks used the 5 speeds that came with the 97-03s.
Old Jul 29, 2008 | 07:30 PM
triton_2002
the I6 probably had more torque than the V6
Old Jul 29, 2008 | 07:39 PM
supertruck's Avatar
supertruck
Alrighty..thanks fellas...I have a 97 supercab with the 4.6,not a real powerhouse either...time to go get a new one I guess
Old Jul 29, 2008 | 08:00 PM
Bobby82490's Avatar
Bobby82490
Is your 4.6 a manual or auto.. if its a auto, it should tow 5000lbs fine.
What size tires and gear ratio do you have.. they can have a huge impact on how it will tow.
Old Jul 29, 2008 | 08:18 PM
96f150's Avatar
96f150
That 94 F250 more than likely had the ZF 5 speed transmssion. THAT transmission would def hold up for sure!!
Rich
Old Jul 29, 2008 | 11:04 PM
supertruck's Avatar
supertruck
She's got a 4.6 with Auto...3.55's for gears and 85R16's for tires...I thought about swapping gears,but it seems like too much of a hassle...
The truck had 385 000 miles on it when i got it,probably closer to 500 000 now..I think it just may flat out be tired..no smoke or leaks though
I don't know if it's been redone at all some point,doesn't look like it...I don't know if anything has been done to the tranny either...
I just don't want to risk it breaking down on the highway somewhere
jdcolding
1997 - 2003 F150
Feb 24, 2007 10:36 AM
blue67stang
1997 - 2003 F150
Jan 6, 2007 05:44 PM
buckndoe
1997 - 2003 F150
Sep 4, 2005 06:28 AM
shewelt
1997 - 2003 F150
Jul 13, 2002 11:13 PM
