engine number
Old Jul 29, 2008 | 02:35 AM
dutchie's Avatar
dutchie
engine number
I have got a 6.9l in a f100 4*4. I would like to know whether you can tell which model truck a engine came out of just by the engine number.
Old Jul 29, 2008 | 10:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
dutchie,
Welcome to FTE and the IDI diesel forum.
The 6.9 was used in the F250 and F350 starting in 1983 to and including 1987.
The following can tell you if the engine was 1983 thru 1985 or 1985 thru 1987.
Block casting........INTERNATIONAL HARVESTER DIESEL ENGINES
6.9L and 7.3L Core Identification
6.9L Old Style Block
Block Casting Number:
On left side of block (beneath oil cooler) 1805440C1
Note: Some 440 blocks are truly new style and must be visually inspected by raised donut around the block heater, frost plug (right rear). Old style below serial number 173828.
Visual Identification: *No counter bored area for block heater
*No defined area on side of block for dip stick
*Thickness of cast iron around block heater 3/8" (.375")
Head Bolts: *7/16, 12 point socket is used to torque head bolts
*Block tapped with 7/16-14 for head bolts
6.9L New Style Block
Block Casting Number: 1807996C1 Note: Some new style blocks have casting
number 440. Above serial number 173828.
Visual Identification: *Has counterbored area for block heater
*Very defined relief area cast in side of block for dip stick tube.
*Thickness of cast iron around block heater 15/32" (.470")
*Latest style (not all new style 6.9) has ribs around head bolts, rear two on left side go from head gasket surface to pan rail - same as 7.3
Head Bolts: *Same as old style 6.9
But that is about as close as the number will get you.
