I need some code 41 help...
Old Jul 28, 2008 | 01:36 AM
kameronth's Avatar
kameronth
Alright, to keep you updated I converted my 88 bronco to Mass Air about a month ago. It was running great. Smog time came around and I failed my high rpm test. It always passed before so I figured I would put it all back to speed desity and try it again. Well, I passed the high rpm test but failed the idle! My ppm was from around 200 to 410 and the limit here is 120. The truck runs great though. So I pulled my codes and I am getting a 41(lean HEGO reading) which must be causing my computer to burn rich. So I replaced my O2 sensor because the ceramic in it was in pieces but I am still getting the same code and failed smog again. I am lost. I am not joking when I say 99.9% of everything on my truck is new. I have new injectors, fuel pressure reg., fuel filter, so on and so on. Where should I start or has anyone else had this same problem? I have it for sale but I would still like to get it fixed for the next guy. Thanks!
Old Jul 28, 2008 | 04:47 AM
TexasGuy001's Avatar
TexasGuy001
Did you clear the codes after the new O2 was installed? Sometimes the code will still be present after the repair. Is the check engine light on? The fuel pressure regulator could make it run rich.
Old Jul 28, 2008 | 10:14 AM
kameronth's Avatar
kameronth
Yeah, I cleared them twice. The fuel pressure reg. is new.
Old Jul 28, 2008 | 10:18 AM
Conanski's Avatar
Conanski
Are you using a single O2 sensor or duals? Did you use a MAF conversion kit or DIY it?
Old Jul 28, 2008 | 12:05 PM
kameronth's Avatar
kameronth
I am running a single o2 but I am also running speed density. I swaped it back and then I was burning rich on the idle with code 41.
Old Jul 28, 2008 | 04:57 PM
jemini's Avatar
jemini
1988 F250 351
I had a 41 code for months after I replaced my old 351 - drove me nuts.
In my case, the idle was just too lean with the original fuel injectors. Even after I put in new injectors I kept getting an on again off again 41 and another code for air upstream during self test. What I finally found was that I had inadvertantly swapped the vacuum hoses comming off the TAD and TAB solenoids. Once I got that straightened out I passed the New Jersey State Inspection the first time through ( I don't think my truck passed inspection in a first time attempt in 10 years.)
You said your injectors are new so my thought is either the O2 sensor isn't being read (faulty wire or something) or that some air (and it could be very little) is being introduced somewhere along the line giving the lean condition.
Are you getting 17" vacuum or better at idle?
Old Jul 28, 2008 | 05:12 PM
kameronth's Avatar
kameronth
Yeah the whole thing has me lost but I actually just sold it this morning. So hopefully the next guy can figure it out.
Old Jul 28, 2008 | 10:24 PM
jemini's Avatar
jemini
Great! No more code 41 to worry about!
wstaylon
Jan 29, 2016 07:29 PM
feeniks4.9
19
Dec 9, 2014 07:35 PM
AZ_Tuc250
Nov 27, 2014 08:11 PM
richmone73
Bronco II
Jan 8, 2011 11:31 PM
pabear89
Oct 18, 2010 08:35 AM
