brake problem
Old Jul 27, 2008 | 04:18 PM
dogg16's Avatar
dogg16
brake problem
1985 explorer right front brake..this is the third rotor and pads in 3 weeks..put a new caliper on too..it just keeps eatin up the pads and scoring the rotor..any ideas what the heck it could be?????
Old Jul 27, 2008 | 09:24 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Dogg, did you mean to type "95" Explorer?
If it's truly an 85, then you have an early model Concept Explorer and it's very rare.....
As to the front brakes, check the line coming to the caliper. The soft line could be swollen and preventing line pressure from bleeding off, or the hard line could be crimped, bent, plugged, etc.
Sounds to me like something is keeping constant pressure on the caliper all the time.....? Does the wheel get very hot while driving?
Old Jul 27, 2008 | 09:34 PM
dogg16's Avatar
dogg16
yes it does..maybe i should replace the soft hose?
Old Jul 27, 2008 | 09:35 PM
dogg16's Avatar
dogg16
yes its a 95
Old Jul 27, 2008 | 11:31 PM
85e150's Avatar
85e150
Check wheel bearings also, spun bearing will make it heat up and wobble to the detriment of the brakes.
Any collision or off-roading damage possible to bend things up?
Rubber hoses excellent place to look also as per prev post.
Old Jul 28, 2008 | 03:23 PM
marragtop's Avatar
marragtop
The brake flex line could be collapsed would give you the problem you described. You may not be able to see a problem with it, but since you've already done the caliper, I'd replace the hose.
