91 Explorer power steering pulley install problem
Old Jul 28, 2008 | 10:04 AM
91 Red Explorer's Avatar
91 Red Explorer
Replaced the power steering pump on my 91. Had a real challenge getting the old pulley off with the rented tool. Installed the new pump and am having a worse challenge getting the new pulley onto the shaft. The pulley keeps going crooked as I tighten the nut to press it onto the shaft. Tried greasing the shaft to no avail. Have tried both the bolt and nut that came with the new pump and went out a bought the tool for removing/installing pressed on pulleys. This 2 hour job is turning into a 2 day challenge!! The only thing I can think of at this point is to try heating the pulley in hot water to expand it prior to installing but I don't know if this will help or not. Any tips or sugestions are appreciated!!
Old Jul 28, 2008 | 01:37 PM
aquanaut20's Avatar
aquanaut20
Heating up in water wont get the desired expansion, but I have had luck heating the pulley in the oven @ 500deg, carefull hot and burns whatever it touched.
Old Jul 28, 2008 | 04:46 PM
91 Red Explorer
How long did you leave it in the oven to 'bake'? Did you still need to use the intallation tool to get it on the shaft or were you able to just slide it on?
1974 f100
13
May 23, 2017 08:52 AM
Don Vito
Jul 1, 2016 12:49 PM
tommyblack
2004 - 2008 F150
Jan 8, 2015 12:02 PM
Marky48170
Jul 29, 2012 09:00 AM
artfd
Electrical Systems/Wiring
Jan 22, 2012 09:41 PM
