mobile phone insatll help
Old Oct 12, 2002 | 02:33 PM
rodney's Avatar
rodney
hi,
I wasnt sure were to post this questions, so I decide to put it here. I recently bought a truck and uninstalled my 3watt mobile phone in my old try and installed it in my new truck. however, i cant get the phone to powerup. I tested the power at the phone and it's getting power. Any ideas?
thanks
rod
Old Oct 12, 2002 | 03:02 PM
kioolt's Avatar
kioolt
I'm not sure about your phone but a recent permanent mount hands free kit I installed had two power wires to hook up. One was hot all the time and the other was hot when the ignition was on. The ignition wire was so the phone would power itself down when the key was turned off.
Old Oct 13, 2002 | 11:52 AM
rodney's Avatar
rodney
yes, that's just like mine. an always hot wire, and a wire thats only hot when the ignition is on. i know both of my wires going into the fuse box are configured this way. there is also power at the phone handset. i was wondering if there was some procedure you had to go through to turn the thing on - like a anti theft device.
rod
Old Oct 14, 2002 | 12:41 AM
groundrat's Avatar
groundrat
How is the ground? May not be a good enough contact. Just my $.02.
Bill
Old Oct 14, 2002 | 05:17 AM
kioolt's Avatar
kioolt
No start up procedure. Just hooked up power. Inserted phone into cradle. Turned on phone and it worked.
Old Oct 14, 2002 | 11:44 AM
rodney's Avatar
rodney
i think i have a good ground (how do you check?), but i'll move it to a new spot just in case.
thanks
rod
Old Oct 14, 2002 | 01:08 PM
kioolt's Avatar
kioolt
One way you could check for a good ground is to put your voltmeter across the ground lead on the phone to a known good ground. Do this with the power on. If you read any voltage you don't have a good ground.
Old Oct 15, 2002 | 12:33 PM
rodney's Avatar
rodney
turns out i had a bad ground - it works fine now after getting a good ground.
thanks
Old Oct 15, 2002 | 07:30 PM
rebocardo's Avatar
rebocardo
