Swaybar Link Install Question
Old Jul 26, 2008 | 05:00 PM
Doubleubar's Avatar
Doubleubar
I am looking to replace the front swaybar links tomorrow and was wondering if it necessary or a good idea to lift the front wheels off the ground. I am not sure if there is a lot of torque on the swaybars when the wheels are sitting on the ground. I would also like to find out how much to torque the bolts to.
2000 F350 EC 4x4
I tried searching this forum and did not come up with any info on the install itself.
Any info or links to an install procedure would be appreciated.
Thanks
Glenn
Old Jul 26, 2008 | 05:13 PM
King0581's Avatar
King0581
When I replaced the bushings in mine I didnt lift it. Not sure on the torque for the bolts.
Old Jul 26, 2008 | 06:12 PM
jrf250's Avatar
jrf250
No need to lift the tires. There is no pressure on this bar. As far as torque on the bolts, I don't know. I just used a impact to tighten mine. Worked great.
Old Jul 26, 2008 | 09:13 PM
AustinS's Avatar
AustinS
Stabilizer link to bracket - 85 ft. lb.
Stabilizer bar-To-Front Spring Spacer Bolts (LH Side Only) - 35 ft. lb.
Stabilizer bar-To-Axle Assembly Bracket Bolts (RH Side Only) - 35 ft.lb.
Stabilizer bar-To-Link Nut - 85 ft. lb.
Stabilizer bar Bracket-To-Frame Bolts -35 ft lb.
Austin
Old Jul 26, 2008 | 09:58 PM
superduty4x4's Avatar
superduty4x4
I would say goodentight is fine for the bolts. I'm going to be doing this soon as well... eager to hear how the job goes for you.
Old Jul 26, 2008 | 10:04 PM
SuperDoodie's Avatar
SuperDoodie
I hope you have a press! Those are a bugger to get out
Old Jul 26, 2008 | 10:07 PM
superduty4x4
That's my concern. I think Ron got his out sans press though- any input Ron?
Old Jul 26, 2008 | 10:08 PM
Doubleubar's Avatar
Doubleubar
Thanks for the Specs
Austin
Austin
Thanks for the specs on the torques for the various bolts.
Glenn
Old Jul 26, 2008 | 10:14 PM
Doubleubar's Avatar
Doubleubar
No Press Required
SuperDoodie
I took the easy way out and bought new OEM links. Did not want to have the possibility of the truck being out of commission while I worked on getting the old bushings out.
I am hoping that it will be a quick job.
Glenn
Old Jul 26, 2008 | 10:17 PM
SuperDoodie
That will be a breeze then
Old Jul 26, 2008 | 11:12 PM
bass3006's Avatar
bass3006
If you are replacing the links, you might as well replace the swaybar bushings that hold it in place, cheap and easy to do. It eliminated some noise in the front end.
Oh and I purchased my links from the dealership, they came with new bolts already pressed in.
mechelement
13
Feb 13, 2022 11:52 AM
Crewcab Turbo
Mar 11, 2012 07:04 PM
fxstdi
Jul 10, 2011 10:14 AM
Marine5811
May 25, 2010 02:52 AM
