C-6 problem again
Old Jul 26, 2008 | 03:59 PM
442john's Avatar
442john
Unhappy C-6 problem again
Well, my 1987 F-350 Dually 6.9 C-6 with banks turbo and over/underdrive lost reverse,again. I had it rebuilt with all high quailty parts as specified per this forum, but it gave out yesterday. Any ideas? I was backing with a load, but I thought this trans was tough? My truck is a 2-wheel drive, do I need a 4-WD??
Old Jul 26, 2008 | 07:33 PM
David85's Avatar
David85
The C6 is a sound transmission, but nothing is perfect. Who did the rebuild and will they warranty it?
How long ago was the rebuild?
Will reverse work when the transmission is cold?
Old Jul 26, 2008 | 08:49 PM
442john's Avatar
442john
Very reputible trans shop in Knoxville, Tn. It seemed to work in reverse fine but it did go into gear slow when first starting? Fluid level was fine and didn't smell or look burnt. I am thinking that I shoutn't have backed up with the load? I think I need 4X4?
Old Jul 26, 2008 | 09:29 PM
ford390gashog's Avatar
ford390gashog
Do you have 1st gear? if you do the low reverse cluthc pack is not the issue. The valve body is the issue. The low reverse plunger pin in the valve body is known to oval and bypass fluid pressure giving a no reverse symptom.
Old Jul 26, 2008 | 11:51 PM
David85's Avatar
David85
I'm leaning towards a valve body issue as well. I'm fighting similar problems with my E4OD at the moment. It doesn't take much to cause problems in the valve body. Worst case scenario, the valve body has to be replaced (tranny can stay in the truck for this job).
I don't think its going to be a big deal to fix. But no matter what is wrong with it, your transmission builder should be made aware about this problem if its still under warranty.
Old Jul 27, 2008 | 11:52 AM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
You will still have 1st gear if the low reverse clutch is not working what You wont have is engine braking in manual low or 1st. Put it in low-1st bring the truck up to a speed in 1st and let off the throttle if You have engine braking the clutch is working and You have an issue in the vale body. If it just coast the low reverse clutch is not working.
Old Jul 27, 2008 | 01:12 PM
442john's Avatar
442john
I have 1st gear and it seems to drive good when going dowm road, just no reverse
Old Jul 27, 2008 | 01:15 PM
442john's Avatar
442john
Dave I know nothing is perfect, I'm probably to blam by backing with a load! I found a 1989 F-350 extended cab 7.3 with banks turbo and a 5-SPD, would that be better than what I have now? They are asking $3900 for it, it has arround 200,000 on truck but motor was rebuilt 40,000 miles ago and the banks turbo was added then.
Old Jul 27, 2008 | 02:04 PM
Lazy K's Avatar
Lazy K
Before you do anything rash do this. If it`s a valve body problem it is no big deal.
Old Jul 27, 2008 | 02:21 PM
1967 Turbo 6.9
Your not going to hurt a C6 by just backing a load up they are tough. They did make some light duty C6's for 302s and 400s. The parts in the diesel C6 are the good stuff.
Make sure You have engine braking in 1st and We'll go from there.
Old Jul 27, 2008 | 03:44 PM
David85's Avatar
David85
Whoa now, don't flog the beast just yet. Thats not a bad truck but if all thats wrong with your current truck is a few sticky valves in the tranny, than just have a little patience. You never really know what you are getting into with any used truck and a valve body issue is not hard or expensive to fix even if you have to do it yourself. If this is all thats wrong with your truck than stick to the devil you know.
Backing up with a load will not kill a C6. I have 3.08 gears and I went to the floor at complete stall trying to push a trailer up hill and over a bump once. Never even a hiccup and it never failed me right up to the day I put the E4OD in.
Old Jul 27, 2008 | 04:40 PM
442john's Avatar
442john
Back again. When I put it into park it make a strang sound like something being stuck into a fan blade? I hope I didn't screw it up by back a load, I do work it pretty hard though. I think it has been less than 2 years since rebuild, I'll have toi find paperwork and i will give the trans shop a call and see what they say after they check it if you guys think that is smart? How hard would it be to make it a 4X4? Gota go church, I'll be back later !
Old Jul 30, 2008 | 10:54 PM
ford trans tech's Avatar
ford trans tech
4x4 will not make it any better , the trans is still the same internally
does it have all three forward gears
if it does , does it shift correctly
Old Jul 31, 2008 | 01:35 AM
442john's Avatar
442john
Yes, it has all three gears and apears to shift fine when in drive, but not reverse.
Old Jul 31, 2008 | 11:12 PM
ford trans tech
then you have either a damaged low-reverse clutch or a stuck valve in the valve body
does the fluid have a burnt smell to it
