Timing chain cover round gasket leaking
Hi,
I will be reinstalling the timing chain cover and want to know the best way to do so without distorting the little round rubber gasket on the backside causing it to leak. Do I put the cover on first and then the steel sleeve on or use the sleeve to help center it and then bolt the cover to the block? Not to mention the front of the oil pan too. I had a slight leak around it last time and it was slinging oil on the cover. Not sure if it's possible for the gasket / sleeve combo to not leak. Any suggestions?
Thank You
Thank You
Personal preference
I would probably get the cover set in place ready to tighten up then slip the balancer hub in to help align it then tighten the bolts. I have to ask are you using a new hub or are you using an old one with a sleeve kit, if the latr one use a sealant when installing the sleeve, or oil could seep through. Just my thoughts. hope they help.-RW
When installing the timing cover on an FE I always slip the spacer onto the crank snout before tightening the cover bolts to make sure the front seal is centered. Don't forget the oil slinger ( the washer-like object that slips onto the crank snout after the timing gears are installed, before the cover goes on). I've heard that if you leave it out it might cause leakage from the front seal.
