injection pumps
Old Jul 26, 2008 | 01:20 PM
bigbubba87's Avatar
bigbubba87
injection pumps
what is the difference between an ip on a 6.9 and a 7.3? or is there any difference? Thanks Justin
Old Jul 26, 2008 | 02:37 PM
AndysFords's Avatar
AndysFords
I believe there is a difference, but they will interchange, but you might better wait till someone else says.
Old Jul 27, 2008 | 07:40 PM
KJLYPW's Avatar
KJLYPW
I believe that the basic pump is the same, however the 7.3 models have slightly larger diameter plunger pistons than the 6.9's as they are designed to deliver more fuel per stroke due the the larger displacement.
Old Jul 27, 2008 | 07:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The IP's and injectors are all physically interchangable.
But the IP and injectors that are designed to go together will usually give better results.
