shock mounts
Old Jul 26, 2008 | 10:26 AM
paredneck33's Avatar
paredneck33
shock mounts
I have a 1978 f150 4x4 and am looking for a pair of front lower shock mounts. You know the ones that rivet to the radius arms. And no one has any replacements. Not Ford and not any of the resto. companies. Any ideaswould be greatly appreciated.
Old Jul 26, 2008 | 01:31 PM
Dr. Dirt's Avatar
Dr. Dirt
did you check the sponsors on the left side of the page?
Old Jul 28, 2008 | 05:39 PM
paredneck33
I've tried a few of them and no luck so far. I was just wondering if anyone had any info as to who the bes candidate might be to try. I have tried NPD, Autokrafters, Jeff's Bronco Graveyard, LMC, and a place called green sales company so far.
Old Jul 29, 2008 | 08:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by paredneck33
I have a 1978 f150 4x4 and am looking for a pair of front lower shock mount brackets. You know the ones that rivet to the radius arms. And no one has any replacements. Not Ford and not any of the resto. companies. Any ideaswould be greatly appreciated.
1978: there are two different types of brackets.
4) D3TZ18126A .. Lower Front Shock Mounting Bracket
Fits 1973/77 F100/150 4WD / 1978 F100/150 4WD before serial number BJ0,001. Also fits 1978 Bronco's before production date 3/20/1978.
4) D8TZ18126A .. Lower Front Shock Mounting Bracket
Fits 1978 F100/150 4WD after serial number BJ0,001 / All 1979 F100/150 4WD's. / Also fits 1978/79 Bronco's after production date 3/20/1978
Both types are obsolete, no longer available from Ford. No Ford dealer has any, no seller of Ford obsolete parts has any, either.
Since Bronco's use the same ones, try FTE sponsor Bronco Graveyard for the brackets.
Just make sure the two brackets match.
Old Jul 31, 2008 | 07:53 PM
paredneck33
Well thanks for the info. I am going to check out JBG next, but I'm just haveing a hard time getting home to call them before they close.
Old Aug 3, 2008 | 11:59 PM
Bonkrr's Avatar
Bonkrr
I'd have to go have a look at mine to be sure, but wouldn't this be the sort of thing that someone with a little metal working experience should be able to fab up rather quickly and inexpensively? Having said that, I realize that some of us have more access to that sort of thing than others.
Old Aug 4, 2008 | 09:36 AM
straightsix4x4's Avatar
straightsix4x4
I got a set for my truck at the junk yard, I'm fairly handy with a torch I was able to just cut the rivets but if you had access to a generator you could get that and an angle grinder, that would work good to. Cost me ten bucks
captain1997
Jan 27, 2014 09:15 PM
kb48
May 21, 2011 07:31 PM
adamax21
2004 - 2008 F150
Apr 24, 2011 11:16 AM
tigman_tim
Offroad & 4x4
Aug 26, 2010 03:07 PM
69crewcab
Mar 20, 2009 03:54 PM
