How do I know which tranny I got?
Old Jul 26, 2008 | 09:36 AM
windsor94's Avatar
windsor94
When I bought the truck off this guy he said it was a newly rebuilt tranny. How do I know which one it is? Im readin through these threads and seein several kinds.
Old Jul 26, 2008 | 09:40 AM
Lazy K's Avatar
Lazy K
Post what your truck is and whether auto or man. Also click on the Tech Info at the top of the forum for more information.
Old Jul 26, 2008 | 09:52 AM
windsor94's Avatar
windsor94
94 f250 with a rebuilt 351w standard cab xl...automatic
Old Jul 26, 2008 | 10:03 AM
quicklook2's Avatar
quicklook2
read the code on your door sticker and post it.
Old Jul 26, 2008 | 01:52 PM
gweeds's Avatar
gweeds
3spd without overdrive = C6
3spd with overdrive = AOD
4spd with overdrive = E4OD
Or you could look at the code on your door sticker, as aforementioned.
Old Jul 26, 2008 | 02:07 PM
EPNCSU2006's Avatar
EPNCSU2006
AOD and E4OD are both four speeds, with fourth being overdrive...
Old Jul 26, 2008 | 02:45 PM
85e150's Avatar
85e150
The AOD was gone after '93, replaced by the AODE or 4R70W. If you can't read the door plate for some reason, there are pics here, just scroll down a bit, then click on the other transmission sections to the left.
The C6 will look the smallest, 4R70W a bit longer in the main case, the E4OD is much larger.
TCI - Ford C4 / C6 Products
Old Jul 26, 2008 | 03:58 PM
gweeds's Avatar
gweeds
I can't believe I just said this:
sorry
Old Jul 26, 2008 | 04:38 PM
windsor94's Avatar
windsor94
well it aint the c6 then seeing how it does have OD. That narrows it to a E4OD or the AOD
Old Jul 26, 2008 | 06:12 PM
Moore558's Avatar
Moore558
Count the number of pan bolts that hold the transmission pan on.
20 bolts = E4OD
14 bolts = AOD/AODE/4R70W
17 bolts = C6
Old Jul 26, 2008 | 06:47 PM
windsor94's Avatar
windsor94
She's got 20 bolts holdin the pan on. looks like its an E4OD. Thanks for the help to all those who responded.
Old Jul 26, 2008 | 08:31 PM
aws3230's Avatar
aws3230
im trying to figure out the same thing my truck is a 96 f150 5.0l v8 need to know if the tranny is a AOD or E40D
Old Jul 26, 2008 | 08:42 PM
Moore558's Avatar
Moore558
Look at my earlier post.
