vin information?
Old Jul 25, 2008 | 01:26 AM
billy12360's Avatar
billy12360
vin information?
i found this on blue oval truck parts.com and was currious if most of this info was correct or not... i know the truck series codes are right... but engine codes and what not.. something like this should be a sticky for this section.
Truck Series Code
  • F10 = F100 - 2 Wheel Drive
  • F11 = F100 - 4 Wheel Drive
  • F25 = F250 - 2 Wheel Drive
  • F26 = F250 - 4 Wheel Drive
Engine Code
  • J = 36 Cyl 223 CID 1BC Carburetor 1961-64
  • A = 6 Cyl 240 CID 1BC Carburetor 1966
  • B = 6 Cyl 262 CID 1BC Carburetor 1963-64
  • B = 6 Cyl 300 CID 1BC Carburetor 1965-66
  • D = V8 292 CID 4BC Carburetor 1961-63
  • C = V8 292 CID 2BC Carburetor 1961-64
  • N = V8 302 CID 4BC Carburetor 1962-63
  • D = V8 352 CID 2BC Carburetor 1965-66
Assembly Plant Code
  • A = Atlanta, GA
  • C = Ontario, Can
  • D = Dallas, TX
  • E = Mahwah, NJ
  • G = Chicago, IL
  • H = Lorain, OH
  • J = Los Angeles, CA
  • K = Kanas City, MO
  • L = Michigan Truck
  • N = Norfolk, VA
  • P = Twin Cities, MN
  • R = San Jose, CA
  • S = Allen Park, MI
  • U = Louisville, KY
  • Y = Wixom, MI
  • V = Kentucky Truck
  • Z = St. Louis, MO
Consecutive Unit Number (Series #) Key Information 1961-66
  • 1961: The 1961 restyled trucks featured less front overhang, more rounded lines, a flatter hood and larger glass area on cab.
  • 1962: Restyled slightly with Ford letering relocated to the grille opening. As in previous years the custom cab option was available on all models. It consisted of woven upholstery, chrome trim on the instrument cluster, white steering wheel, two-tone interior, bright metal grille and windshield reveal moldings.
  • 1963: A rectangular grille pattern and hood side emblems are new. The 6 Cylinder 262 CID now available.
  • 1964: The F-100 styleside got a new separate double wall bed with a single handle tailgate latch. The F-100 was available with either 6-1/2 food bed or 8 foot bed in Stepside or Styleside form. The bed floor on the Stepside was wood covered and the Styleside bed floor was steel.
  • 1965: The twin I-beam suspension was added. It combined the strength of a solid front axle with the softer ride possible in a design using independent front suspension. The parking lights were now located above the headlights.
  • 1966: New grille added. The grille now featured a horizontal bar and twin spear shaped openings above two rows of small rectangular cutouts. A new Deluxe Ranger option included bucket seats. Trucks equipped with the Ranger dress-up package are identified with a Ranger emblem.
Old Jul 25, 2008 | 09:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The engine codes are incomplete and one is wrong.
Some like the 302 & 292 4V are for F500 and larger trucks only.
There are no FT engines listed.
D = 352 2V = 1965 only
Y = 352 2V 1966
J = 1965 240 1V
FTE already has VIN decoders, and there are at least 7 ppl here that can decode VIN''s, so why would this be needed?
Old Jul 25, 2008 | 11:07 AM
billy12360's Avatar
billy12360
i dont know, i was clicking around blue oval, and was getting T.O.ed by all the 57 interior parts, that i started clickin things... and came across that and figured i would ask if it was correct figured i would ask some experts. and figured maybe some one else could use this to get some sort of idea what their truck is, i mean more then just a "ford truck"
Old Jul 25, 2008 | 11:15 AM
NumberDummy
I could list EVERYTHING that pertains to 1961/66's, and that would be the only way to do it.
But that would take hours of research (mostly for the rear axle codes themselves, because there are 100's and are mindboggling).
So, even if it was a sticky, some ppl wouldn't use it...so why bother.
If someone lists their Warranty Plate codes, both Don (camperspecial65) and I can decode all of it in less than 4 minutes flat. Don now has the exact same info I do.
Old Jul 26, 2008 | 11:35 AM
IsoGrifo's Avatar
IsoGrifo
no need to yell at him! now I bet he feels like an
incompetent piece of crap(had to censor that...) because you don't think it's important enough or worth anyone's time, but it was worth his!
Old Jul 26, 2008 | 04:06 PM
camperspecial65's Avatar
camperspecial65
He isnt yelling IsoGrifo....Bill is 1000% correct...things like paint and DSO codes and the like are gravy compared to rear end codes...the trans codes can be a bit fun as well, but the rear axles are by far the longest list if one were to attempt to compile ALL of them for 61-6 F100-350 trucks...
When we chat next time Billy, I will enlighten you a bit more...but needless to say, its time consuming
- cs65
Old Jul 28, 2008 | 10:41 AM
garbz2's Avatar
garbz2
Its all about re-direct.......
Garbz
