Sponsored by: Auxito
No power 2001 s crew
Old Jul 24, 2008 | 11:17 PM
bansheeduner's Avatar
bansheeduner
Cool No power 2001 s crew
my truck seems to bog until i hit 2000 rpm i changed the plugs which were a chalky burnt light tan color and i cleaned the maf, throttle body and changed the fuel filter but its still bogging encept when the truck is cold please help
Old Jul 25, 2008 | 03:52 PM
KingRanchMan02's Avatar
KingRanchMan02
What engine and trans do you have? How many miles are on the truck? Is the CEL on? Any mods to the truck or drivetrian?
Old Jul 25, 2008 | 04:10 PM
bansheeduner
no engine lights just scanned it came up clean its a 5.4l with auto trans and 100k
Old Jul 25, 2008 | 04:38 PM
KingRanchMan02
Could be just the summer heat and humidity taking its toll.
Old Jul 25, 2008 | 04:56 PM
bansheeduner
no humidity here its DRY!!!!!!!!!! whats the best way to clean out my fuel injectors?
Old Jul 25, 2008 | 09:47 PM
KingRanchMan02
Well you can't deny the heat! Get some Seafoam and follow the directions on the can for fuel treatment and injector cleaning. Good luck!
Old Jul 25, 2008 | 10:00 PM
AzBlueWolf's Avatar
AzBlueWolf
I was having the same problem, Banshee
try disconnecting the battery so that the puter will relearn all the settings...
seems to have helped mine
Old Jul 25, 2008 | 10:01 PM
AzBlueWolf's Avatar
AzBlueWolf
Sea Foam <~~ great stuff!
Old Jul 26, 2008 | 09:56 AM
bansheeduner
i already sea foamed it it is great stuff it seems to stumble or have no power from take off or at 1500 rpm
Old Jul 26, 2008 | 12:00 PM
KingRanchMan02
I agree with AZBlueWolf about restting the ECM. Disconnect the battery ground cable for 30 minutes. Hook it back up and the ECM will have lost all of the information in the fuel tables and other logged information. It will be like the truck when it rolled off of the assembly line, it has to learn how to run with all the sensors feeding it new, fresh information. It is certainly worth a shot. Good luck!
Old Aug 21, 2008 | 09:10 PM
bansheeduner
disconnected the battery and got new high flow cats in the rear and deleted the two front cats and truck is still a dog except when it is cold after sitting over night but when it heats up its soooo slow until 2100 rpm what gives no dtcs no signs of anything please help
Old Aug 21, 2008 | 10:35 PM
AzBlueWolf's Avatar
AzBlueWolf
someone suggested checking the fuel pressure regulator
remove the vacuum line and plug the line, and see if it drives any better
Old Aug 22, 2008 | 07:46 PM
96f150's Avatar
96f150
It def has something to do with one of your sensors. I would replaced your ECT (Engine coolant temp) sensor. The computer runs in closed loop mode until it gets to operating temp, then it goes into open loop mode and gets its inputs from the sensors.
Good Luck
Rich
Old Aug 22, 2008 | 08:02 PM
efx4's Avatar
efx4
Is your truck using more fuel than before the problem? If so then it could be a sensor like as mentioned, causing the ecm to add more fuel due to improper signals. A failing fuel regulator or a weakining fuel pump could be some more possibilities.
Old Aug 22, 2008 | 08:34 PM
96f150's Avatar
96f150
To check your fuel regulator, take the vacumn line off of it, and if fuel comes out of it, the regulatoris bad.
