Brake booster
Old Jul 24, 2008 | 09:55 PM
Customcab's Avatar
Customcab
Brake booster
Came across a 77 model with front disc brake's; I got the calipers and front disc from a 73 model given to me from fellow FTE member. My question is will the brake booster from the 77 model fit onto my 65 model firewall, I guess the real question is the brake push rod; will it need changing?
Mitch
Old Jul 25, 2008 | 01:41 AM
Haaser's Avatar
Haaser
Yes take the one from the newer model truck. Cut a little off and shorten it and weld it back up. The booster will bolt up no problem just need to shorten the brake pushrod. Depending where you weld it up you can change the pedal position.
Old Jul 25, 2008 | 05:41 AM
jowilker's Avatar
jowilker
Mitch and others, the firewall and floor are basically identical, as are the chassis from the rear cab mount points out to the ends of the frame rails from 65-79.
With a couple exceptions (65/66 4X4 & 350) about anything that will work on one will fit the other.
John
Old Jul 25, 2008 | 07:11 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Mitch
Do you have the bracketry ( Cantalever ) ? You may want to take a look at
the tech Artical and that may help a lot!
https://www.ford-trucks.com/article/...rd_Trucks.html
Wally Womack
Old Jul 25, 2008 | 05:07 PM
old4x4_f100's Avatar
old4x4_f100
Yes it will work but you will have to change the pushrod lenght. I tried many different boosters and never got one to work until I cut one and shortened it. Just take the one and use it as a reference. Thats what I did and am loving the power brakes.
Old Jul 25, 2008 | 05:10 PM
jowilker's Avatar
jowilker
You can drill a new hole and move the location as an alternative to cutting.
John
Old Jul 25, 2008 | 05:30 PM
old4x4_f100
^^^^ in the brake pedal? I thought of this too. But I have access to a welder and saw so it was easy. But you might be able to just drill a new hole. It would be way easier.
Old Jul 27, 2008 | 09:44 PM
Customcab's Avatar
Customcab
Sorry for the late reply; thanks for the input; I'm alittle confuse (John) on drilling a new hole; please explain in more detail.
Mitch
Old Jul 28, 2008 | 05:25 AM
jowilker's Avatar
jowilker
Mitch, you are relocating the mount point. My 66 has the original st. drv. brake pedal, after being converted to PS and C6 tranny. I believe I drilled a new hole in the booster arm about 1 1/8" to drop the pedal hang position. I recall my knee hit my chin using the factory hole.
When you cut and weld you are moving the mount point. I didn't have a welder.
John
Old Jul 30, 2008 | 09:52 PM
Customcab's Avatar
Customcab
Thanks John;
I removed the power booster & master cyclinder from a 77 truck; yesterday; the push rod (brake) seem to already been welded with a piece of flat metal and a 1/4 inch hole for a bolt to attach the arm to the pedal. I will try and post pic's soon and got question in regards to the wire connection on the master cylinder & portion valve. I wonder if I can convert my brake light wires onto one of these wire; or need to add the brake light mechanism on the pedal.
Mitch
Old Jul 31, 2008 | 11:38 PM
Pro-Street/StateTK
CustomCab
Heres a link to a thread that I posted on that may help clear up some of your
questions.
https://www.ford-trucks.com/forums/7...-an-olguy.html
P.S Don't weld your pedal, drill the flat bar! (Cantalever).
Wally Womack
otonedog
Jul 30, 2013 09:16 PM
Spyderjohn
Apr 18, 2012 11:01 PM
DarkWolf40
Aug 25, 2008 11:15 AM
72stepside
Feb 11, 2003 11:15 AM
spartamouse1
1966 - 1977 Early Broncos
Sep 16, 2002 02:37 PM
