Alternator/ Voltage Regulator Wiring
Old Nov 4, 2002 | 06:05 PM
Mil1ion's Avatar
Mil1ion
Old Nov 5, 2002 | 03:09 PM
keeb69's Avatar
keeb69
My 1997 Ranger has gone through a overhaul, i have done a 302 swap from a 86 mustang, my question is does any one know how to wire the alternator to the voltage regulator from scratch, i have a factory ford alternator for a 87 mustang, and a wells vr, any help would be greatly appreciated
Old Nov 5, 2002 | 03:34 PM
keeb69's Avatar
keeb69
sorry the truck is also equipped with all after market gauges, a ammemeter, ans voltage meter, both are analog
Old Nov 5, 2002 | 04:02 PM
steve83's Avatar
steve83
How many wires come off the alternator & how many heavy-gauge? Describe the alt as best you can because there are several types that work differently.
Basically, the answer is: wire it the way it was on the original (donor) vehicle.
Old Nov 5, 2002 | 07:44 PM
keeb69's Avatar
keeb69
the alternater has 4 places for wires, large one i have connected to the batt. grounf i have conected to a ground, i have sto, and flo left on the alternator, and on the reg i have a (i s f a) posts, a basic wells regulateri dont know what to hook up tp the regulater from the alternater, and where, and i also dont know what to put on the terminals marked ( i s a f)??? please help
Old Nov 5, 2002 | 08:06 PM
Mike W's Avatar
Mike W
Wire the F (field) terminal on the regulator to the Field terminal on the alternator. The stator term on the alt is not used however it can be used for an electric choke.
The S term on the regulator needs to go to the ignition switch so it will have +12 when the engine is running. The purpose of this is to tell the regulator to start supplying voltage to the field terminal when the engine is running.
The Bat terminal goes to the Bat connection on the solinoid. Be sure the regulator case is grounded.
Old Jan 20, 2009 | 10:19 AM
mac10guy's Avatar
mac10guy
the s terminal goes to the sta. on the alt
the i port on the regulator goes to the ignition.
sta can ALSO have a wire to the choke.
Old Jan 20, 2009 | 10:47 AM
Franklin2's Avatar
Franklin2
You are describing the version that uses the idiot light in the dash. The way he was describing to hook it up uses the ammeter in the dash. Ford had two ways of wiring the older alternators.
