Lights won't go out
Old Jul 24, 2008 | 07:10 PM
pisgahmountain's Avatar
pisgahmountain
Lights won't go out
The interior and bed lights on my 1999 Ford f-250, 7.3 diesel won't shut off even after a long period of time. I have to disconnect the batteries to shut them off. The plate on the door jamb that has the cut off plastic lever has some rivets or some sort of fasteners that I don't know how to remove. I suppose there is a switch malfunction on the interior of the jamb if I just knew how to get inside.
Old Jul 24, 2008 | 08:11 PM
Zip's Avatar
Zip
Is the door ajar light on all the time as well? It may just be a sticky door switch, shoot some wd40 in there open and close the door a few times. This sometimes will free up the switch.
Old Jul 24, 2008 | 09:13 PM
pisgahmountain
Thank you for the reply. The dimmer switch was turned all the way up causing the lights to stay on all the time. Stupid of me but true.
Thank you
Old Jul 24, 2008 | 10:34 PM
Zip's Avatar
Zip
OK.....nuff said
flytb28
New Member Introductions
Jan 6, 2007 08:49 PM
bgodkin
Feb 12, 2001 11:19 PM
