d80 swap?
Old Jul 24, 2008 | 12:44 AM
nortonrider's Avatar
nortonrider
d80 swap?
Anyone ever stuff a Dana80 in a highboy? I have one from my Dodge Cummins donor truck and thought I might use it in place of the 60 that's there now.
Old Jul 24, 2008 | 02:00 AM
BrentNewland's Avatar
BrentNewland
Front or rear?
Old Jul 24, 2008 | 09:55 AM
dirtfrmr57's Avatar
dirtfrmr57
Based on this question, should we assume that you have scrapped your plan to put the Ford body onto the '92 Dodge donor chassis? Did you find specific problems/roadblocks with that idea?
Old Jul 24, 2008 | 11:11 AM
nortonrider
Ya, I just couldn't bring myself to do it. One of the reasons I'm doing this restomod project is that my Dad has owned this truck since it was new and if I change too much it won't really be his old truck anymore. I don't feel too bad changing to a Cummins as the 428 that was in there was obviously not original anyway.
There was some things I didn't like about using the 98 Dodge chassis. The rear axle would have to be moved approx. 5" forward, the body mounts would all have to moved and the chassis has significant dips in it just aft of the cab and up front at the rad support. I also do not like the CAD front D60 setup. And then there was the unknown considering it's not been done much.
I DO however really like the D80 LS rear axle. HUGE! I have a D60 for the front as well- although low pinion.
Old Jul 24, 2008 | 11:37 AM
75F350's Avatar
75F350
Installing a D80 rear axle is not any different than retro-fitting any other axle.
Interesting concept about using the dodge frame and entire drivetrain.
I was out off roading some time ago, and I spotted a late 70's crew cab on a dadge chassis. It looked odd and I could not figure out what it was. While i did notice that the bed had been shortened quite a bit, I could not fugureout what made this such an odd configuration. I did notice the frame hanging down quite a bit, this still had me scratching my head.
It finally hit me as I drove up to take a better look. Not only had the rear been shortened, but the front had been extended. The fenders were lengthened, as was the hood.
I must say the guy did a great job, but it was a little different looking.
Throwin a 70's ford body on a later dodge chassis is interesting, but does require quite a bit of work.
Just installing any axle under a ford trucl is a piece of cake.
Old Jul 24, 2008 | 11:55 AM
nortonrider
I've seen pics of that truck. Apparently he didn't move any body mounts and didn't alter the wheel base. I would think the way he did it would be more work.
The Dodge frame is quite beefy but is made in two pieces and slip jointed together and rivetted.
ReBilld
Dec 8, 2015 05:21 PM
smokersteve
Jun 6, 2012 12:35 PM
lacucarachaloco
Jun 1, 2009 11:50 PM
fordbeast_80
Oct 13, 2004 07:15 AM
beastybronco
Jul 26, 2004 10:09 PM
