Tire Pressure
Empty, I run 55 front and rear. This is a little more than is necessary but it gives me a good solid ride and is easy to maintain.
When I load, I inflate higher than I think is necessary (never over max) until I can hit a scale and then I adjust to the tire table. In my neck of the woods anyway, there are unmanned but operational scales everywhere.
The only time I use pressures higher than the load table is when I'm carrying my camper. The load tables would put around 55 front, 60 rear, but the camper is so top heavy that I find going to the max of 80 takes out a lot of the sway I would otherwise get.
I can also attest to the fact, from experience, that running more air than necessary WILL wear the inside of the tire out faster than the outside. As expensive as these tires are, I'd prefer to get as much wear out of them as possible. On my current truck, I have the stock BF Goodrich tires and at 40k miles, they still have a decent amount of tread left. I plan on replacing them before the snow flies, because they are starting to lose a little traction in the snow.
First thing is to drive the vehicle down a hwy "UNLOADED" for awhile(15 minutes or so...when its dry out). Then pull over and check the temp in at least 3 places. In the middle, outside & inside of the tire tread. If the temp is higher on the outside and inside of the tire, the pressure is too low and needs to be raised a bit. If the temp is too high in the middle of the tire, the pressure is too high.
It takes a little time to get it perfect, but after you find out what its supose to be, you WILL get the absolute best tire life.
When the rears are hotter than the fronts, I adjust them up, and likewise the other way around...
I also get great tire wear that way too...
Great tip... I think I will get a non contact thermometer gun and throw in my glove box, and take along a tank of air. I always wondered the best way to figure out how to get the best wear out of them, this sounds like the easiest one I have heard of so far.
I got the truck in December and the front tires are worn on the outside, but the rears are OK. I was wondering if 80 was too high on the rears (seems high to me...my first Super Duty)? I don't want one to blow on me. I am running the fronts at 65 right now to try to wear the middle of the tread.
Dick
YOU CAN'T GO WRONG WITH THE TEMPERATURE METHOD!
BTW, in my opinion, Firestone got a bum deal years ago with the blown tire issue on the Explorers. Ford recommended a tire pressure that was waaaaaay too low in an attempt to make the vehicle ride better. I butted heads with every Ford rep that came to the dealership!
Then why was Firestone the only one that had that problem that dramatically?? I say it was a combination of lower pressures and poor tread adhesion due to sub-par assembly materials. Lower pressure alone shouldn't have caused it. Look at the ratings of any tire and you'll see that a belted radial is designed to work (that includes heat dissipation) anywhere from min 25psi to it's max psi rating. Ford's recommended 30psi on the Exploders should not have been an issue.
Ugh, I gotta stop reading all these tire threads.......
Is firestone tires as good as say Michelin?.....absolutely not.
Yeah, it maybe 30 now, but years ago, they said like 26 or so.
On my 99 Exploder the factory rating was 30. I still got the freebies. I think the 26 rating was for earlier then mine even, and I'd have to agree that that is just asking for trouble.
Firestone took it up the azz on this on big time. I have a friend that owns a mid 90's explorer, and I saw the door post that recommended 23psi in the rear tires. This was done to soften up the ride. Yes, firestone did admit to using rubber that was too old, but that wasn't the only problem, in my opinion. Ford decided to soften up the ride by running too low air pressure in the tires. What happens when running a tire too low on air will cause the tire to flex too much, weakening the sidewalls, and generate heat. Heating the air causes it to expand, then tire failure.
