I had 1 possibly 2 glow plug connectors leaking on my truck. Well I just checked yesterday and noticed no more oil is leaking. I degreased the oil pan and transmission housing and no more oil is leaking on them. Has anyone else had a similar leak with the glow plugs that stop leaking on their own?
They usually don't stop leaking on their own, but you could try something. Pull the bus out some, check the o rings, and if they are fine, gently put some lube on them, even grease, than push them back in. It did fix mine, but I've had a broken-one too..., so. It worth to try though.
I actually tried to pull them off ,but I thought they might break so I pushed on the two that were leaking kind of firm around where the plastic part meets the block, and they don't leak anymore. When I think about it there was a small gap between the plastic and the block (around the connector). Now the gap is gone. I will keep an eye on them. I haven't smelled burnt oil in the cab for a few weeks now. Were going camping this weekend so I will see what happens when it's "worked" a little.
my 04 6/0 stoped leaking to i have 55k on it runs great
