95 Explorer Headlight / Low Beam Driver side
Old Nov 17, 2002 | 12:25 AM
cberentsen's Avatar
cberentsen
After replacing the bulb and still no low beam, drivers side, I checked and found there is a fuse for each side - they were both good, with power on both sides. No voltage at the bulb connector though. This tells me (per Haynes wiring diagram) the wire is open to the lamp or a 'Lamp Out Warning Module'failure.
Where is the Lamp Out Warning module?
Old Nov 17, 2002 | 01:17 AM
Mil1ion's Avatar
Mil1ion
Probably under the dash connected somewhere close to and in conjunction with the headlight switch.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 17, 2002 | 04:35 PM
cberentsen's Avatar
cberentsen
Thanks for the help. However, according to the Haynes wiring diagram, there would be no power at the low beam driver side fuse if power were interrupted at the light switch. The problem is limited to the wiring from the fuse to the 'lamp out warning module' and then to the bulb.
I can't locate the 'lamp out warning module'.
Thanks Again!
CB
Old Nov 18, 2002 | 01:36 PM
cberentsen's Avatar
cberentsen
Ford Wins!!
Brought to dealer. I'm out $290 ($90 for the $10 module, and $200 labor to install behind the dash).
Old Nov 18, 2002 | 01:54 PM
Mil1ion's Avatar
Mil1ion
Torsen Rick
Aerostar
32
Mar 1, 2011 10:15 PM
sammycooks
Apr 26, 2010 08:00 PM
svt2205
2004 - 2008 F150
Oct 1, 2008 07:44 AM
KJRowe
Electrical Systems/Wiring
Apr 15, 2007 11:47 AM
cstigas
Aug 20, 2004 08:13 AM
