35" tires 4.10 gears ?
Old 07-22-2008, 10:20 PM
o_i_f_03_04's Avatar
o_i_f_03_04
o_i_f_03_04 is offline
Is anyone running 35" tires with 4.10 gears. If so whats the RPM range in overdrive going 65 or 70 MPH. I have the 3.55 gears now and want to upgrade.
Old 07-23-2008, 09:53 AM
twp's Avatar
twp
twp is offline
I am running 35'' tires with 410 gears. At 70 mph I think I am turning 1900 to 2000 rpm.
Tim
Old 07-23-2008, 03:44 PM
o_i_f_03_04
Thats the RPM range I want to be at. Thank you Tim
Old 07-23-2008, 05:58 PM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
If it was me i would go with 4.56s.. while you will be turning a few more rpms on the highway, it would easily be worth it for the power increase.
Old 07-23-2008, 08:00 PM
o_i_f_03_04
I drive 45 mins to work and back and i typically drive 75 to 80 MPH and I dont really use my overdrive because when i do use it i end up pushing the pedal a little further to keep my speed up. So now my question is would 4.56's be screaming at 75 to 80 MPH ? 2300 RPM's would be ok for me but any more then that would be more then I want at 75 to 80 MPH with overdrive on
Old 07-23-2008, 10:43 PM
97Handshaker's Avatar
97Handshaker
97Handshaker is offline
save the 1500 bucks and buy a beater work car. i think that would be better.
but seriously, i think 4.56's would put you about 2200-2300 at 70mph
if you never plan to tow anything really heavy or upgrade to bigger tires, like 38's then 4.10's will work for you.
4.10's put you near the stock rpm's
Old 07-24-2008, 05:17 AM
Bobby82490's Avatar
Bobby82490
I looked it up in a gear ratio calculator and at 75mph you turn a little over 1800rpms now.. and with the 4.56s you would be turning a little over 2300rpms.
Which i would be fine with 2300 rpms.. if you had a stock f-150 with the 3.73 ratio with the 255/70r16 that some came on some of them you would also be turning 2300rpms.
Old 07-24-2008, 05:15 PM
97Handshaker
^^^^do you have a website for the gear calculator???
Old 07-24-2008, 08:34 PM
Bobby82490's Avatar
Bobby82490
Old 07-25-2008, 04:30 PM
97Handshaker
thanks for the link!
Old 07-25-2008, 07:00 PM
bla1879's Avatar
bla1879
bla1879 is offline
Sorry to ask another question, but i was also considering getting the 4.56s. I currently have 35s and the stock 3.73 gears out back. My buddy told me that id get better fuel mileage going to the 4.56s. is this true? because wont the rpms be higher and so youd be using more gas or am i mistaken somehow?
Old 07-25-2008, 09:29 PM
o_i_f_03_04
i dont think RPM's matter. what matters is how far you push the pedal down. with the 4.56's you could accelerate a little faster with less peadal, you'll save gas with lower gears in city driving
Old 07-25-2008, 09:52 PM
Bobby82490's Avatar
Bobby82490
Yeah the main reason you "could" get better mileage is because it is MUCH easier to get the truck moving.
Old 07-25-2008, 10:41 PM
bla1879's Avatar
bla1879
bla1879 is offline
ok sweet thanks guys sorry i your thread!
frigerator
03-29-2015 09:57 PM
Shwan_89HD
26
10-01-2012 07:27 PM
fordmanva
03-13-2012 09:23 PM
sbechtold
1999 to 2016 Super Duty
01-25-2008 12:53 PM
Pkupman82
Offroad & 4x4
05-08-2007 10:34 PM
Quick Reply: 35" tires 4.10 gears ?
