need advice for ignition switch to toggle switch conversion.
Old Nov 25, 2002 | 06:48 PM
icelander's Avatar
icelander
a few months ago i turned the ignition switch on my bronco and it wouldnt stop cranking the starter. needless to say the switch is shot. im starting the rebuild process but im gonna drive it and rebuild it at the same time since winter is here and ill need a 4x4. i was thinking of insted of just getting a new switch, id put a couple of toggle switches on the panel and use them to start and run the truck.
my question is : is this as easy as cutting a few wires and running them to the switches or is it more involved than that? security is not an issue. im trying to avoid dismanteling the steering column and hoped i could just cut the wires under the dash and run them to the switches.
thanx in advance for any help.
Old Nov 25, 2002 | 07:15 PM
Mil1ion's Avatar
Mil1ion
Just by-pass the starter part.
You need the key function in RUN to allow the resistance to the coil and ignition mod so you don't burn the coil out.
Just interrupt the start postion with a start Button under the dash.
Run two wires from the switch to the starter solenoid.
One to the Battery side and One to the "S" terminal.
Everytime you push the button,the engine turns over.
If the key is in the run position, it will start and run.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 28, 2002 | 08:05 AM
lee's Avatar
lee
Ice,
I had this exact problem a few years ago. It's not the ignition switch. It's the starter solinoid. The contact's wear down from the high cranking current and tack weld together. Tapping it with a screwdriver will sometimes break them back apart.
Before I starting any Mod's to the ignition switch I would replace the solinoid. They are relatively cheap and are easy to change.
Hope this helps,
Lee
Old Nov 28, 2002 | 02:45 PM
kioolt's Avatar
kioolt
The ignition switch isn't in the coloumn. It's ad the base of the column connected by a rod to the key cylinder. It wouldn't be necessary to dismantle the column to replace the ignition switch.
Old Nov 28, 2002 | 05:19 PM
Mil1ion's Avatar
Mil1ion
cedman
20
Sep 2, 2015 06:31 PM
fordguy76
Electrical Systems/Wiring
Aug 15, 2015 08:52 AM
tbugher62
Sep 24, 2014 11:13 AM
landers0440
17
Sep 6, 2014 03:37 PM
wally b
Feb 9, 2014 06:28 AM
