Sponsored by: Real Truck
Problems going into reverse
Old Jul 22, 2008 | 07:47 AM
chris3421's Avatar
chris3421
Ok, I hope someone can help, so he I go. I have an '03 v10 auto trans, 4x4, with 120k. The problem is shifting into reverse from park, the trans doesn't go into reverse. I have to put it into drive then into reverse, to back up. Anyone else have this problem, or have any ideas what to look for? Thank you.
Old Jul 22, 2008 | 08:56 AM
rugermack's Avatar
rugermack
Do you have a lot of play on the linkage on the steering column ? Or will it not actually go in even when the shifter does find reverse ?
Old Jul 22, 2008 | 09:08 AM
chris3421's Avatar
chris3421
There is not a lot of play. It shift into reverse ok on the steering column, but the trans does not go into reverse.
Old Jul 22, 2008 | 09:40 AM
rugermack's Avatar
rugermack
Some one else will jump in, but doesn't sound good.
