Hello guys,
I was wondering if one of y'all could do me a favor. I have a OBS powerstroke truck, and it only has a total of 38 gallons of fuel when topped off. Do any of you have measurements for an excursion fuel tank? i want to put one in my truck, if i can.
Thanks guys!
The tank angles up toward the back, and I'm sure there are indentations in the top, like I said in the earlier post these were rough measurements. Cannot see the whole tank due to the shield around it. I'm not really sure that the tank goes all the way to the body. The length and width are close, however I measured the depth at the largest part of the tank.
Ok that leaves plenty of space for 50 gallons of air/shielding/sender... makes sense.
I suppose the width is all i really needed to know, as long as it fits between my frame rails.
thanks again guys!
Dan
