axles and seals
Old Jul 21, 2008 | 01:30 PM
pappie's Avatar
pappie
axles and seals
9" REAR from 72 F100, 3.25 gears,any one ever do the seals under a shade tree or is time to go to the shop. pap
Old Jul 21, 2008 | 06:55 PM
60F100's Avatar
60F100
Which seals are you talking about. The only one that might be a problem is the one where the yoke goes in. Axle seals are fairly easy. The bearings have to be pressed off and back on. If you replace the brarings I would use the later sealed bearing versus the earlier bearings that are lubricated by the differential oil.
Old Jul 21, 2008 | 07:15 PM
pappie's Avatar
pappie
First thanks for your reply, I do not know but there is fluid, checking one wheel it appears to be the axle as opposed to the wheel slave, and the carrier is low on grease cant feel any with my finger..but at the same time that I found this had to top off master cyl. have just bought this truck, maybe put 300 mi. on it , has been parked since I found the problem.
Old Jul 21, 2008 | 07:36 PM
pappie's Avatar
pappie
when you say they have to be pressed in and out is that something that I can do.. Pap
Old Jul 21, 2008 | 07:53 PM
pappie's Avatar
pappie
how does this posting work ? is it in real time? All my replys have come through email, and when I get back the help has gone. I am lost again..
Old Jul 21, 2008 | 10:11 PM
SillyValleyF250's Avatar
SillyValleyF250
If you can replace the bearings with the sealed units, that's probably a good thing to do. If not, there is no reason you can't pull the old seals out of the ends of the axle tubes, and (gently, gently, carefully) bang some new seals in with a seal driver (or, failing that, a big socket, or a properly-sized chunk of wood with a flat end, or ...)
The axles don't have C-clips or anything dumb like that in the pumpkin, so removing the brake backing plates should allow the axles to be pulled out without problem. Just make sure the axles themselves have a good surface for the seals to ride on.
I'd drain and refill the axle with some good gear oil. Look in the manual, or online, for the right stuff, which should be available from your local auto parts store. One thing to watch for, is if you have limited slip (or whatever Ford calls it,) which might mean you need to get a different lubricant, or some sort of additive to keep the clutches in the limited slip unit gripping.
As for posting, if you're set up like I am, the posts show up here pretty much real-time, and a notification is sent to your email account, with a link leading back to this thread.
Old Jul 22, 2008 | 08:03 AM
pappie's Avatar
pappie
Thanks! I got a message about vent holes in the axle, where are they..P.
Old Jul 22, 2008 | 09:12 AM
SillyValleyF250
Generally, the vent holes will be at the uppermost part of the axle. That is, somewhere near the center of the top of the pumpkin, at the top of the differential pumpkin housing, at the center of the rear axle.
Usually these are little fittings (many times plastic) meant to let air in and out of the axle housing, but designed to keep dirt from being sucked or blown in too easily. Lots of times, these look like a little hose nipple wearing a dustcap.
Just make sure these are clean, and that you can blow/suck on it without obstruction.
Old Jul 22, 2008 | 09:15 AM
SillyValleyF250
Oh, about pressing the bearings on/off...
You'll probably need to take your axles to a shop or garage that has an arbor press or hydraulic shop press.
Unless you have a press with the bearing separator, there's really not any way to do this at home.
Luckily, this takes a mechanic with a press less than 10 minutes to do both axles, if he has a clue what he's doing. Not a big deal.
Old Jul 22, 2008 | 06:52 PM
pappie's Avatar
pappie
Hey, and thanks again, I looked for a nipple fitting on top there is none the only thing on the Axle is the brake line brass fitting and it had a hose which had dirt in the end, took it off and cant blow thru it.. P.
Old Jul 22, 2008 | 07:44 PM
SillyValleyF250
Either clean out that hose, or replace it. When you uncork the pumpkin to drain and refill the gear oil, check to make sure you can blow through the nipple that hose was attached to.
--Silly
Old Jul 22, 2008 | 07:57 PM
pappie's Avatar
pappie
HEY Silly, On this axle there is no drain plug, do I have to open it to drain? filled it and took a ride , less noise but lots of smoke, I will remove wheels tomorrow and check for leaks, brake fluid , I like this web page, sure has been helpful, Thanks..P.
Old Jul 22, 2008 | 08:43 PM
pappie's Avatar
pappie
Hey SV. THIS SHOULD GO TO A PICTURE TEST.. p
Old Jul 22, 2008 | 09:03 PM
SillyValleyF250
Hmm... on that one, you might have to either pump it out by hand, or pop the pumpkin off the housing after you've pulled the axles. I think there's a plug, with about a 1/4" or 3/8" sqare fitting in it that you can turn out to fill the axle. I believe the right way to tell you've filled the diff enough is when it begins leaking back out of the hole you're putting it in.
Old Jul 22, 2008 | 10:32 PM
pappie's Avatar
pappie
This is the first leak that I found also leaking at the other wheel. P
