No, it won't make a damn difference in power. He's just opinionated.
so you don't think on the top end having more air it won't make a difference.I said the 6637 filter because I had a stage 1 afe went to the bigger filter from addvice from others on this sight,and noticed a big diff in power from the stage 1, and he said cheap,so just trying to help.
but since I am opinionated it won't make a damn difference.
and if he wants to the z28 cut the wheel and run over his ***.
OR......you could buy a Cobra Mustang and smoke his azz in a vehicle that is actually made for racing? These trucks can be made to be quick.....but think of Kris's quote from awhile back........"Racing a 7.3L is like bringing an expensive sword to a gunfight"
The camaro should be embarrassed in the first place that you (a PSD) beat him off the line and held him to 75. Its impressive enough! This thread leaves a bad taste in my mouth, last time i "raced" i got a little ticket lol
so would going from the stage 1 to the 6637 make a difference? I have one guy on here saying yes, and one saying no. And there was another guy from a different site that said yes. I don't no what i should do
Originally Posted by crack
I ran the 6637 for a long time, went to the afe stage 2 and noticed like a 200 deg drop in egts....seat of the pants powerf, probably the exact same.
Only way you'll know for sure with your setup is to buy the 6637, go to the track, make a couple passes with the AFE, then a couple with the 6637. At least the 6637 can be found for a relatively small amount.
