Brake/Brake line Question...
Old Jul 20, 2008 | 06:19 PM
schlepprock250's Avatar
schlepprock250
Ok....when I apply the brakes normally,my truck pulls to the RIGHT,I was looking and the brake line on the DRIVERS side has what appears to be a kink in the line. I replaced all four rotors and pads about a year ago and I also replaced the caliper on the passenger side front. Could the kink in the line cause it to pull to the right?
Thx...Schlepprock
Old Jul 20, 2008 | 06:26 PM
megawatt00's Avatar
megawatt00
Yes due to not enough pressure/fluid going to the side with the kink.
Old Jul 20, 2008 | 06:34 PM
schlepprock250
its not a fully closed off kink,but its still kinked,you can definately see a "place" in the line.
Old Jul 20, 2008 | 06:35 PM
megawatt00's Avatar
megawatt00
Then the line is restricted. Kinda like when you pinch off a garden hose.
Old Jul 20, 2008 | 06:45 PM
schlepprock250
Right...I guess thats as good a way to describe it as any...lol, so if its just restricted a little, will it make it pull tp the right when the brakes are applied?
Old Jul 20, 2008 | 06:53 PM
PaysonPSD's Avatar
PaysonPSD
No matter the cause, if the left front is braking less then the right front it will pull to right.
Old Jul 20, 2008 | 06:54 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Yes. Less pressure going to the driver's side caliper and full pressure to the passenger side caliper means:
PASS-side caliper engages first, fully
DRIVER-side caliper engages later & likely not fully
PASS-side does most of the braking
that'll cause it to pull to the right - might help with parallel parking though!!
Old Jul 20, 2008 | 07:39 PM
megawatt00's Avatar
megawatt00
Yup! Plus the kink will weaken the line so you may want to change it before it bursts.
