Are Wix fuel filters any good, seen in popular mech. they came out with new fuel filter 33818 ( element and lid are a single unit). And what oil filter is best.
How much are the Wix filters? If you go that route make sure you hang on to your old cap in case you want to switch back. I'd also check out the gasket that goes between the lid and the bowl. I've read that Wix has changed to a flat gasket on top that requires a film of MOTOR OIL on the gasket to prevent leaks. The old bevel gaskets just use a film of diesel. One of our members learned this the hard way, so use the oil with the flat gasket and save yourself the headache.
I've always used the Motorcraft filter since they are very reasonable at most stores.
i use nothing but wix filters..other then my AFE...use the napa gold wix filter 3518 ,,,you re use the stock lid...too many people have problems with the lided filter rout..i been useing this napa gold filter for 3 years,,every 5000 miles and only hand tight my cover..Knock on wood i have never had a leak...
I ordered to quick. just ordered 33818 fuel and 51734 oil filter from fleetfilter. I wanted a trans filter but they must be out cause when I hit the order button it never showed. oh well I'll give the fuel filter a try, thats what I get for being in a hurry
