power window gears
Old Jul 19, 2008 | 02:02 PM
bigbubba87's Avatar
bigbubba87
power window gears
i have an 87 f250 and i was wondering if anyone knew how to put gears in the passengerside door for the power windows. i have no idea how to even begin to do this. any ideas welcome. thanks Justin
Old Jul 19, 2008 | 03:12 PM
ccecilm2's Avatar
ccecilm2
If you already have power windows and want to R/R them see . . .
https://www.ford-trucks.com/forums/7...otor-swap.html
If you want to upgrade from manual cranks to power it may not be too hard since Ford may have all the wiring in the door already. Someone will probably be along pretty soon with a good idea.
Old Jul 19, 2008 | 04:50 PM
bigbubba87's Avatar
bigbubba87
it has power window on it now. but the gears that make the window go up and down are stripped out and i wanted to put new gears in it but dont knw how to
Old Jul 20, 2008 | 06:37 AM
Gevans17's Avatar
Gevans17
wihdow gears
Probably has 3 plastic cogs in the gearbox which are broken. Buy the cog kit at AZ. Pull the power window motor, pull cover off of the gear box (3 screws) clean out the old grease and pieces of old plastic cogs, replace. new cogs kit usually runs about $15
Old Jul 20, 2008 | 06:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DOAZ62234A24B .. P/W Motor Gear Kit / Comes with the plastic gear, 3 rubberized plastic dowels (cogs), new cover and the grease.
MSRP: $31.60 / FTEpartsguy.com price: $22.75
Fits: 1981/90 F100/350 / 1980/90 Bronco / 1984/90 Bronco II / 1970/90 cars.
Old Jul 20, 2008 | 06:57 AM
ccecilm2's Avatar
ccecilm2
Window motor gear kits are available follow link below for a little more advice . . .
https://www.ford-trucks.com/forums/6...otor-tech.html
