Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Transponder key question
Old Jul 19, 2008 | 01:14 PM
esebm's Avatar
esebm
Hi Guys,
I happened to come across the key cutting station at a Home Depot store and the word "transponder keys" caught my attention.
The clerk there put my 2004 Escape key into the "chip finder" gizmo, hit the "TEST" button and nothing happened. He tried it 5 times and then he told me "there's no chip in this key"!
So I had me a regular key cut which opened the door but, as I had expected, didn't start the vehicle.
So, I'm wondering, why didn't this thing recognize the chip? If there is a problem, how can I get a second key programmed if the original code is not detected?
Old Jul 19, 2008 | 11:29 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Simply put, their 'test' equipment is not for this type of 'transponder' key.
Every key has a random binary code that it transmits. It is not possible to change this code. When the car's computer is programmed for a new key, it is told to 'accept' this code for the new key. No changes are made to the actual key.
As a result, there would be no way for Home Depot to program your key, nor would it be possible for them to stock all of the 'possible combinations' to sell you a matching one, as there are literally billions if not more possibilities.
Now the old transponder keys back in the day had something like 16 different combinations, so it was easy to stock all 16 different keys, and then just match up whichever one is the same as the old key, but that is no longer the case.
The only way to program the key on these is to use a Ford NGS or WDS diagnostic tool. There might be an aftermarket tool that can do this as well, but I'm not familiar with any. However, if you already have two working keys, you can program a third without needing the diagnostic stuff.
Old Jul 20, 2008 | 10:02 AM
esebm's Avatar
esebm
The machine at Home Depot is supposed to detect which chip (e.g. Texas Instruments, etc.) is in the key. You may be right, maybe their test gear is not laid out for the kind of chip in the Escape key.
As to programming the key, I do not have a second key to program a third one but I know for a fact that there are dozens of locksmiths in the Austin area that do program 2nd keys. Unfortunately, they charge just about the same as the Ford dealershios, around $60 - $75.
If a simple locksmith can do it, I don't see why Home Depot couldn't do it.
Old Jul 20, 2008 | 02:35 PM
aj7885's Avatar
aj7885
keys
The lockshops use a computer to extract the info from the cars electronics. Then their computer tells the car to accept the new key they cut. This system is rather pricey so they do get a premium to do it.
Old Jul 20, 2008 | 02:43 PM
esebm's Avatar
esebm
Well, I've heard a different story. They take the info from the existing key and program this info into the new key. Apparently, they don't need the vehicle for that.
Does anyone know anything definitive?
Old Jul 20, 2008 | 07:03 PM
5_labsownus's Avatar
5_labsownus
You do not program the keys on Ford vehicles. You program the vehicle to the key. If you have 2 working PATS keys and purchase a 3rd from a dealer or locksmith you can program it to the vehicle.
I did this on my 02 escape.
It works the same as programing the remote entry.
But you must have 2 working keys or the dealer will need to program it for you.
I know of no locksmith in this area (some are high teck) that can program with only 1 key.
Old Jul 21, 2008 | 09:23 AM
esebm's Avatar
esebm
I'm always willing to learn from the experts.
However, sometimes I just don't get it:
I have one key and I need a second one. If the car is programmed to the key, how does that work? Shouldn't the second key be programmed according to the car AND the original key?
Old Jul 21, 2008 | 07:00 PM
aj7885's Avatar
aj7885
The reason you need two keys to program a third is to prevent a valet, or a mechanic, or a friend, from making a copy of your key and programming it from the one you gave them to use. By having to have two programmed keys, only you can enable a third or fourth key. By the way a small lockshop in our central Illinois city has the equipment to do the Ford keys. They charged me $50.00 to program a second key and then $20.00 for the third. Took only 20 minutes to do.
Old Jul 21, 2008 | 07:35 PM
esebm's Avatar
esebm
Okay, the third key is no problem, I can do that when I have two keys.
But how did he do the second key? Did he actually go into your vehicle or did he take the coding info from your first key?
Old Jul 22, 2008 | 09:05 PM
aj7885's Avatar
aj7885
The programmer plugs into the car. Call a local lock shop and see if they have the equipment. I will bet they are cheaper than a Ford dealer.
Old Jul 22, 2008 | 09:37 PM
sfcwoodret's Avatar
sfcwoodret
This was helpful information for many of us. Thanks.
Old Jul 23, 2008 | 11:08 AM
esebm's Avatar
esebm
I called a bunch of locksmiths here in the Austin area, most of them charge even more than the dealerships. Looks like a lucrative market to me.
Old Jul 24, 2008 | 08:37 PM
MazdaRangerGuyInSTL
The "Scanner" plugs into the OBDII port on the vehicle.
Then the Security module is accessed.
The Security module will at this point make you wait ten minutes (to help deter theft... even thieves can obtain Ford diagnostic equipment).
After the ten minute wait you tell the car you want to program another key to it. It will tell you to insert the key and turn it on.
Then it says "programming complete" and give you the option to program another key.
As far as I know, only the FORD diagnostic equipment has the capability to even access the security module. While some aftermarket equipment MIGHT be available that can do this, it isn't going to be the el-cheapo scanners you can buy at autozone. Even our $3000 Genisys equipment can't do this.
The Ford equipment can cost upwards of $20,000+, which is why they have to charge you so much for it in order to pull any kind of reasonable profit...
dchamberlain
1997 - 2003 F150
50
Apr 27, 2019 10:59 AM
DirtySCREW
Nov 12, 2013 06:56 PM
Dectek
2004 - 2008 F150
Feb 15, 2007 10:19 AM
HawaiianStyle
2004 - 2008 F150
16
Sep 8, 2004 09:38 AM
