Modular V10 (6.8l)
Premium gas?
Old Sep 5, 2008 | 05:22 PM
  #31
Heavy_Metal's Avatar
Heavy_Metal
Originally Posted by mwsF250
As GT4.6 pointed out, 89 is only 2.5% more expensive than 87 these days. I have to wonder how much mpg increased when the ECU doesn't have to retard the ignition on 87....
The problem is probably that your ecu isn't retarding the timing since your knock sensor may be bad, causing a ping since it cant "see" the knock.
Old Sep 8, 2008 | 12:38 PM
  #32
mwsF250's Avatar
mwsF250
That's possible, but the way it comes and goes at steady throttle leads me to believe it was the ECU adjusting the timing trying to get to optimal.
My theory is that it keeps trying to advance to the hard coded "optimal" timing setting, but then knock sensor detects it starting to ping so it has to back off. Then it tries again. A continuous effort to maximize hp/mpg without excessive knock.
As I understand it, that is how most ECU's operate with regards to timing.
Old Sep 19, 2008 | 05:24 AM
  #33
Move over I'm coming's Avatar
A couple of other things to consider on trucks with higher miles is:
The computer temperature sensor may be out of parameter.(slow to adjust air/fuel trim)
The thermostat may be sticking open or opening too soon. (cold condition)
The O2 sensors are out of parameter (slow to adjust air/fuel ratio)
Eventhough these will set a MIL light (check engine) when totally shot they can still be bad and NOT set a MIL/CEL light.
O2 sensors are especially prone to this. The heaters go bad and they won't adjust the computer signal for 2-3 seconds. Not 5 app. times per second as required.
The MIL light wont be set off until app. once every 5 sec. is detected.
Go to a service garage and have them look at your "live run" parameters.
You will be very surprised at what they can see.
Operating temp, Fuel trim, O2 response time, oil pressure, cylinder balance, Timing, plus alot more.
If all else fail bring your truck to the dealer and reflash your PCM to your local area tune. (your truck may have been at sea level -vs- high altitude or vise versa)
Good luck and thanks for reading my 2-cents in advise.
Old Sep 19, 2008 | 03:47 PM
  #34
jamesblonde82's Avatar
jamesblonde82
if it doesnt call for it, simply dont do it.
A_Freebird
Oil & Lubrication
13
Jan 4, 2016 09:00 AM
BossHawg
2010 - 2014 Ford SVT F150 Raptor
Sep 6, 2010 05:55 AM
Diverdom
21
Jun 4, 2010 08:21 PM
DruzeTito
13
Nov 21, 2003 03:14 PM
lallen
Offroad & 4x4
Mar 6, 2001 04:11 AM
