Sponsored by: Auxito
2001 f150 bogging
Old Jul 19, 2008 | 10:03 AM
bansheeduner's Avatar
bansheeduner
2001 f150 bogging
i have an 01 screw with a 6 inch lift and 35 inch tires in the morning the truck drives great no bogging but during the day the truck kind of lags or bogs until the tach hits 2000 rpm does any one know what it could be other than that the motor runs really good
Old Jul 19, 2008 | 11:10 AM
ranger88a's Avatar
ranger88a
Check your fuel filter.
Old Jul 19, 2008 | 11:31 AM
bansheeduner
ok thats what i thought it might be thank you any other things it could be i cleaned the air filter on it yesterday
Old Jul 19, 2008 | 11:36 AM
khadma's Avatar
khadma
Carpenter Local 745
CEL on?
Bad cat?
Check for pending DTCs.
Old Jul 19, 2008 | 12:12 PM
bansheeduner
nope no check engine light and it runs very good over 2000 rpm
Old Jul 19, 2008 | 12:21 PM
khadma's Avatar
khadma
Carpenter Local 745
No light does not mean no pending codes though.
Mileage?
When was the last tune up? Service? What was done?
Old Jul 19, 2008 | 12:24 PM
bansheeduner
it was just scanned no codes and it was just serviced plugs ect but the fuel filter wasnt changed though and it just passed emissions two days ago
Old Jul 19, 2008 | 03:33 PM
xtrford's Avatar
xtrford
4.6 or 5.4?? I assume the weather is fairly hot where you are at, I know mine gets a little power loss when the engine runs hot along with outside temps of 85 degrees and up. I would imagine that since these engine run lean as it is, higher temps will cause power loss.....I also know when it is cool and raining outside my truck will get up and go much better.
I would also like to add the 35's are not helping the situation either, might want to consider 4:10, 4:33, or 4:56 gears to help you out there.
Old Jul 19, 2008 | 07:33 PM
bansheeduner
its a 5.4 my buddy has the same setup and his doesnt bog like mine does
Old Jul 19, 2008 | 07:42 PM
AzBlueWolf's Avatar
AzBlueWolf
clean the Maf and throttle body
Mark
Old Jul 21, 2008 | 09:49 PM
bansheeduner
cleaned the mass air flow sensor and throttle body and replaced the fuel filter changed the plugs and wow!! i only did 2 so far on the passenger side doing the rest tommorrow but what a difference thanks guys for your help
Old Jul 24, 2008 | 10:03 PM
bansheeduner
its still bogging it started again and im not sure what the problem is please help!
saauvenshine
Nov 19, 2015 09:46 PM
fordboy_52
Nov 15, 2015 11:33 AM
frank5079
13
Oct 25, 2015 09:49 PM
02GrayPowerStroke
Feb 20, 2015 05:27 PM
wolff7.3
Jul 22, 2014 02:13 PM
