Stumble
Old Oct 7, 2015 | 04:19 AM
frank5079's Avatar
frank5079
Stumble
I have an occasional problem on take off with my truck, a '95 300 six and 5 speed. I'll ease off the clutch to go and as the truck moves, it will sometimes "stumble" or "hiccup" and bog momentarily. Now if I were to rev it up to 2500 rpms or higher and then ease the clutch it'll still stumble but without the bog. Any ideas what could be causing it to do this??
Thanks in advance,
Frank
Old Oct 8, 2015 | 05:57 AM
dixie460's Avatar
dixie460
Does it do it at low RPM's and full throttle too? Put it in second gear when you're rolling slow, so that the motor is almost bogging down. Then floor it. If it stumbles when you do that then it probably just wants a new set of plugs and wires. Cap and rotor wouldn't hurt either.
Old Oct 8, 2015 | 01:18 PM
frank5079's Avatar
frank5079
If I'm sitting in traffic, the truck will be idling fine at about 1000 rpms and then it would drop momentarily. It's when I'm letting off the clutch and trying to get rolling that it will stumble...if I bring the revs up to 2500 to 3000 rpms then the stumble isn't too bad.....
Old Oct 9, 2015 | 06:02 AM
dixie460's Avatar
dixie460
1000 RPM is too high, should be about 750 or so. Check for a vacuum leak, that'll give you high idle and stumbling.
Old Oct 9, 2015 | 08:06 AM
frank5079's Avatar
frank5079
I will try that...although I haven't heard any vacuum leaks...
Old Oct 9, 2015 | 05:23 PM
rla2005's Avatar
rla2005
Unless you are a dog with very acute hearing you will NEVER hear 99.9% of the vacuum leaks.
Old Oct 9, 2015 | 08:35 PM
toby tough's Avatar
toby tough
Check all the hoses and stuff with a can of starting fluid or carb cleaner. If it revs when you spray a certain area you may have found your leak. Found my upper intake leak that way. Good luck.
Old Oct 10, 2015 | 12:27 AM
Toplait's Avatar
Toplait
Maybe coil related...
Old Oct 10, 2015 | 08:38 AM
frank5079's Avatar
frank5079
Yup, thanks, that's how I check for vacuum leaks...
Old Oct 21, 2015 | 02:54 PM
frank5079's Avatar
frank5079
All my vacuum lines were old and cracked so I went ahead and replaced them all. I still have the stumbling problem...any other ideas?
Old Oct 21, 2015 | 07:19 PM
88XLTLariat's Avatar
88XLTLariat
Have you checked your TPS?
Old Oct 22, 2015 | 06:55 AM
frank5079's Avatar
frank5079
I'll give that a try....
Old Oct 22, 2015 | 08:40 AM
Demonhawk's Avatar
Demonhawk
As someone who has had a similar issue which is related to the EGR, I would try pulling the vacuum line off the EGR and plugging it. If issue goes away it may be related to the EGR Control Solenoid or EGR valve itself.
Old Oct 25, 2015 | 09:49 PM
frank5079's Avatar
frank5079
One of my mechanic friends at work says he doubts it's the EGR because the problem only occurs at low idle....
At this point, I've replaced the spark plugs, plug wires, distributor cap and rotor along with the IACV and the problem is still there albeit to a lesser degree...I'm guessing that since I've thrown this much into it, I may as well replace the TPS too....
obscurity
Aug 5, 2013 12:19 PM
FordRun
May 25, 2012 01:53 PM
RyanMiller
15
Apr 8, 2006 08:19 AM
Viper1837
Sep 7, 2005 06:18 PM
Saurian
Feb 9, 2004 05:55 PM
