Problem with Pop Out Window Latch
Old Jul 18, 2008 | 09:59 PM
MavJoe's Avatar
MavJoe
How do you remove the Pop Out Window Latching Mechanism's?
I have a broken one on the sliding door window, it's the one nearest the rear fortunatley and not near the lock. But it's still possible to pry it open enough to break in if someone really wanted to, not to mention it flaps and vibrates when going down the freeway because of the busted latch.
I was out at the Junk Yard today getting other things I found a van out there with those pop out latches tried to remove it but I was not successful, I was just wondering is there a Special Tool I need for this job?
Meantime I guess i'll crazy glue the existing one and hope that holds and just won't open the window til I can fix it (my brother will really love that).
Old Jul 19, 2008 | 12:38 AM
Club Wagon's Avatar
Club Wagon
Presume on "85 E-150"? From memory: 1st remove Philip's screws holding latch to steel window frame, then unscrew entire latch from button that goes thru glass.
Old Jul 19, 2008 | 03:09 PM
MavJoe's Avatar
MavJoe
Guess I was tryin to pull a bad one off the junker, when I tried unscrewing it from the button all it was doing was turning the button, I tried holding the button with vice grips and it seemed like it was backing out but then I noticed it wasn't. Suppose I can try again because the crazy glue fix didn't take all I succeeded in doing was bonding my fingers
got2bjoester
Escape & Escape Hybrid
Apr 11, 2017 06:16 AM
Lukes66
Feb 9, 2011 03:46 PM
WiNgRg
Mar 9, 2010 05:03 AM
bigric
Oct 22, 2004 07:47 AM
97F-150Hal
1997 - 2003 F150
May 19, 2004 08:04 PM
