Big issues
Old Jul 23, 2008 | 12:36 PM
Broken40's Avatar
Broken40
thanks for all the killer info. guys, you've put alot of confidence back into me wanting to use this site for all my ford needs...thanks again.
Old Jul 24, 2008 | 03:10 PM
80broncoman's Avatar
80broncoman
Originally Posted by Broken40
K....so do either of these pictures tell you my problem, if you look at baron's motor and mine, they are identical to each other, other than the oil pan....
Wrong his engine is a 302 look close at the area between where the engine mounts bolt to the block and the head gasket surface.
See the difference? Yours is much taller.
Old Jul 24, 2008 | 05:17 PM
Kemicalburns's Avatar
Kemicalburns
They look the same to me, also look at the front pic showing the dizzy, it sits well below the intake manifold like a 351w would.
Old Jul 24, 2008 | 05:35 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Yeah, that engine is not a 302 it's a 351w.
Old Sep 11, 2008 | 12:29 PM
Broken40's Avatar
Broken40
So i found out that the truck i have only came with a 302 or 351M or 400 installed, thats why im having such a problem with the pan......so i called jegs to get some advice on what pan to get and they told me that i would need this......
http://www.jegs.com/images/photos/600/697/697-30530.gif
Old Sep 11, 2008 | 12:46 PM
Kemicalburns
crack smokers, have you tried a 4wd 351w pan that is rear sump. you might also look into a pan from a van perhaps. the 351w block hasnt really changed so the pans should all match up just run a regular volume oil pump.
car polisher
Mar 7, 2017 09:48 PM
Mr. Ed
Nov 8, 2016 10:00 AM
hasteranger
Apr 29, 2016 03:28 PM
Bill W
26
Jul 17, 2011 06:53 AM
