Is this a good RV" cam??
Old 07-17-2008, 05:02 PM
saleen065's Avatar
saleen065
saleen065 is offline
I bought a master engine kit and they sent me a cam in the kit that is suppose to be an "RV" cam. I'm curious if this is a correct cam for a 390 and if it is indeed an RV cam:
Melling SYB-23
Int. Lift-.432 duration 273 centerline 113 rocker ratio used 1.75 Hyd. lifters
Exh.Lift-.436 duration 281 centerline 111 rocker ratio used 1.75 Hyd. lifters
The duration at .050 lift for intake and exhaust are 192 and 199
I'm using Speedpro pistons that will yield close to 10:1 compression I am told. The heads are 1975 stock 4V heads.
Old 07-17-2008, 10:39 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
The extra exh duration will be a good thing, as to the exact status of the cam as an RV ? Not sure and alothas to do with the rest of the build as to how the cam will play in harmony so.. better intel on the build is in order if you want to know if the cam is a compliment to your build.
Old 07-18-2008, 09:54 AM
saleen065's Avatar
saleen065
Cam will be installed straight up. stock heads with stock rockers. Pistons are as I mentioned earlier as is the 4V stock intake. Transmission is the stock C6 auto. I'm looking at a set of headers from Summit for $129.00 unless someone knows where I can find them new cheaper.
Old 07-19-2008, 09:31 AM
Barry_R's Avatar
Barry_R
Barry_R is offline
Sounds like a stock cam. Too small. Might spark knock at 10:1
Old 07-19-2008, 10:33 AM
saleen065's Avatar
saleen065
location I bought the cam from said it is an RV towing cam.
Old 07-20-2008, 10:59 AM
saleen065's Avatar
saleen065
Will this cams work with my setup?
Here is a Lunati cam I found at Summit:
Lunati 00053 - Lunati Hydraulic Flat Tappet Camshafts - summitracing.com
It has lots of duration (300) and a .514 lift. The pistons I am using are the speedpro H395P. I'm using stock 1975 heads and the block is a 1968 block. No deck work and the heads are totally stock so no mill work on them. I want to be sure the cam lift isn't too much for the pistons and will this be a good toque cam. The cam I got with my master engine kit seems a bit weak or as stated by someone, a stock setup cam. I will be running long tube headers and a stock 4V intake with a Holley 600 carb ( came with it originally).
Old 07-21-2008, 09:11 PM
saleen065's Avatar
saleen065
OK UPDATE............ I got off the phone with Melling and found out the cam I got is in fact a stock cam and not an RV cam. The cam Mellings sells is an MTF-4 which has some great specs:
Brand: Melling
Product Line: Melling M-Select Torque Cam
Part Type: Camshaft
Part Number: MEL-CL-MTF-4
Cam Style: Hydraulic flat tappet
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 292
Advertised Duration: 282 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.484 int./0.510 exh. lift
Lobe Separation (degrees): 107
Old 07-23-2008, 09:30 AM
fordeverpower's Avatar
fordeverpower
fordeverpower is offline
192 and 199 duration at .050 is stock, i bought my old truck that had an rv cam. Decoded it to be a clevite rv stock grind, wtf. That melling mtf-4 is old technology and so is that lunati.
I like the lunati voodoo series, they just came out with FE grinds, or the Crane (we have been raising prices) powermax, or the comp cams extreme energy series.
dimora
176
04-26-2018 08:00 PM
simons22
15
08-22-2015 08:19 PM
F-250 restorer
10-05-2010 07:24 PM
CowboyFromHell
04-22-2009 11:08 PM
moore89
13
03-24-2004 12:55 PM
Quick Reply: Is this a good RV" cam??
