1/8" over full mark
Old Jul 17, 2008 | 03:17 PM
mybigredford's Avatar
mybigredford
1/8" over full mark
hey guys, i was adding alittle oil to my engine the other day and i let it sit for a bit and checked it again, and it nneded alittle more etc...
anyways i went and checked it one more time just to make sure the next day and it seems to be about a good 1/8" over the full mark, will this hurt antything, i am think probably not but thought i would ask??
guess i didnt let it sit long enough before i checked inbetween.
Old Jul 17, 2008 | 03:27 PM
bdrummonds's Avatar
bdrummonds
if the level gets too high you can create a foaming situation from the crank whipping the oil in the pan into froth. (its hard for the HPOP to push bubbles and fire injectors)
1/8 inch should not be too much a case for concern.
Old Jul 17, 2008 | 03:29 PM
danskool's Avatar
danskool
Go Bills !
I would think your fine. i been there before. I had mine on the full mark. Then i parked over on the side of my house. I pulled the stick again and it was a 1/8" over. And thought "what the frig". I decided it was because the gound was unlevel and the truck was tipped.
All depends were you park and level are you are. Now i only check oil in one spot in my driveway were it is the most level. Somthing like this bugs the crap out of me and instead of worring about it i would drain it out by loosening the oil pan fill plug and leaking out a quart. Then i can sleep with no worries, but that is just me. Will it hurt anything? Propably not.
Old Jul 17, 2008 | 04:44 PM
indebt's Avatar
indebt
another very good reason to get the Fumoto drain valve!
Old Jul 17, 2008 | 07:13 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
In the future, when you are adding oil, just stop a dodge hair short of full.
I know it seems simple, but a quart low at oil change won't hurt a thing...
Old Jul 18, 2008 | 04:01 PM
mybigredford
i usually leave it about 3/4 on the full mark all the time, this time i guess the sun was in my eyes or something.
ive been driving around for a few days and everything seems fine, thanks for the help.
