hard steering ....
Old Jul 17, 2008 | 10:53 AM
campinclan's Avatar
campinclan
hard steering ....
I took my '04 F150 to the local shop for an oil change and lube job, when I got it back the steering is pretty tight and getting worse as I drive it, took it back to see what happened , mechanic had it for the day ,said he see nothing out of the ordinary (no leaks) , said he's talked with the ford garage and they are leaning towards rack and pinion .... any thoughts ??
Thanks ,
Campinclan
Old Jul 18, 2008 | 02:17 PM
thirsty99's Avatar
thirsty99
Here's a crazy thought. You didn't specify if your truck is 4x4 or 2x4. If it is 4x4 could it be possible the 4x4 selector was bumped to the 4hi or 4lo position? Just a thought.
Old Jul 18, 2008 | 03:33 PM
campinclan's Avatar
campinclan
Thanks for the thought , 4x2 ......... been told the pump "normally" will either be good or bad , no intermittance, .ball joints?? , rack and pinion ?? , mechanic doesn't really seem to know where to start. Got in the truck today and it steered just find . Go figure .
Old Jul 18, 2008 | 03:53 PM
slc10844's Avatar
slc10844
You might want to change the P/S fluid. I think Ford recommends ATF not regular power steering fluid.
Old Jul 18, 2008 | 03:59 PM
campinclan's Avatar
campinclan
I suppose it's worth a try , just not sure what happened since the oil change , one day it steers good and the next you can't hardly turn the wheel . no leaks to be seen
Thanks for the reply !!
Old Jul 19, 2008 | 06:05 AM
FX4Jim3's Avatar
FX4Jim3
Check and lubercate the U-joints on the steering column.
That what was wrong with mine.
cost less than a rack and pinion
Old Jul 19, 2008 | 08:51 AM
campinclan's Avatar
campinclan
worth a try , sounds like it COULD be an easy fix, fingers crossed
Thanks for the info,
Campinclan
Old Jul 19, 2008 | 10:47 AM
1saxman's Avatar
1saxman
Maybe the 'techs' added some incorrect fluid to the PS reservoir.
Old Jul 23, 2008 | 06:01 PM
campinclan's Avatar
campinclan
FX4Jim3,
GOOD JOB, You The Man !!!!
U joint in the column was the problem , replaced sterring column a WHOLE lot cheaper than a rack.
Would like to thank you ALL for the replies, I believed the mechanic used your input as well for for a starting point
Thank again ,
Campinclan
Old Jul 24, 2008 | 07:26 PM
baitmaster's Avatar
baitmaster
Jeez, the U joint was worn out already? Guess they better put a zerk fitting on them.
Old Jul 24, 2008 | 08:11 PM
campinclan's Avatar
campinclan
Unhappy
Pretty small u-joint, not sure there would be room to get a grease gun in there. Ford garage had them in stock, looks like it's been happening more and more ..........
Old Jul 28, 2008 | 08:16 AM
FX4Jim3's Avatar
FX4Jim3
I wonder how many people got charged for a rack and pinion that didn't need one?
