Serious RV Type Question
Old Jul 16, 2008 | 07:31 PM
Medic 66's Avatar
Medic 66
Greetings everyone. I am new to this part of the forum as I mostly stay in the diesel area. Here is my question:
It is time to get an RV. I know what I want inside and about the size, slides, yada yada yada. Situation is this...bumper pull or 5'er?
What are the pro's and con's to a 5'er. I have borrowed friends 28ft bumper pull and seemed to be a good trip pulling that unit.
Truck details are in the signature. Would like to know as may good and bads about each kind as I plan to purchase very soon.
Thank You All!!! RC
Old Jul 16, 2008 | 07:34 PM
crown180's Avatar
crown180
Having had both - 5th wheel wins - but most important is the floor plan that you prefer. The 5th wheel tows better in my opinion but at the same time never had a problem with the TT
Old Jul 16, 2008 | 07:41 PM
gstanton's Avatar
gstanton
I agree with look for the floor plan that suits you! You can tow either one, so that is not a real factor. A bigger issue might be slide outs, bed comfort (easy to make?) location of bathroom - and is it available when the slide out is closed? Back kitchens tend to shake rattle and roll... things like that.
I've only had "regular" tow behinds, but the floor plans have always been the deciding factor.
Old Jul 16, 2008 | 07:55 PM
Medic 66's Avatar
Medic 66
Great information guys.....keep it coming.
I agree with the floor plan comments and beleive it or not I have found layouts in both designs that I like and would suit us. that again is why I am looking for more input on things to base my decision on.
thanks again!! RC
Old Jul 16, 2008 | 08:53 PM
socalduner's Avatar
socalduner
I would go with the 5er, Ive pulled both and like the 5th wheel alot more. The TT was ok but there was alot more sway from semi's and it was harder to unhook from the tow vehicle. They say it's better having the weight over the rear axle than at the very back too.
Old Jul 16, 2008 | 08:57 PM
firesoutmatt's Avatar
firesoutmatt
After having both and finally getting the biggest one I could find. Fiver all the way . If your staying in the 20' and under range stay with a TT anything over that the fiver is the way to go.
Old Jul 16, 2008 | 10:59 PM
Greywolf's Avatar
Greywolf
The only reservation I'd have about a fiver is that on some - cracks form on the sidewalls right where the overhang on the front comes out from above the front storage compartments. It doesn't happen to all of them, but on the biggest ones it can be a real annoying problem.
Once it happens to one, it can be nearly impossible to resolve it.
Old Jul 16, 2008 | 11:24 PM
mudmaker's Avatar
mudmaker
You also need to look at where you will be pulling it. 5ers are tall. If you like to head into the woods this can be a huge issue. Just need to keep the height in mind. Dont want to be like the guy in that bank security video!!
Old Jul 17, 2008 | 05:53 AM
elmo8641's Avatar
elmo8641
5th wheel. it tows alot better. the layout is a big factor. with a 5th wheel and can pull doubles in most states, so if you get a boat, or 4wheeler you can pull it behind your 5th wheel camper.
Old Jul 17, 2008 | 12:35 PM
Medic 66's Avatar
Medic 66
Most of the layouts I found that I like are in the 24-28 foot range
Old Jul 17, 2008 | 12:36 PM
Medic 66's Avatar
Medic 66
No woods for me!!!!
Old Jul 17, 2008 | 12:40 PM
Greywolf's Avatar
Greywolf
Some other thoughts - with a TT you need a load distribution hitch and a sway control.
A fiver doesn't need an LDH, and they are usually stable enough that sway control isn't needed either.
Both of these contribute to faster hook-up and setup.
Shock Absorbers can be added to either one, and comes stock on some of them. They can be helpful.
No trailer I know of just now has anything like a swaybar/torsion bar in the suspension.
One of the plusses with an LDH though, is that you can vary the lift at the tongue to compensate for different loading.
Also keep in mind that if you want dual sway control bars, the front ball mount will be on the LDH head. If it doesn't have two mount points for them, the LDH would have to be changed if you wanted to double them up.
By the way - avoid LDH heads that use spring pins to retain the load bars. The spring pins wear out, and can let a bar drop out of it's socket. I always liked Reese/Huskey because they did away with that.
Old Jul 17, 2008 | 01:03 PM
BradyCouchman's Avatar
BradyCouchman
that is a very good point also in many states you can have passengers in the 5er so if you have kids or a wife that likes to stop every 50 miles to pee or eat or something just put them in the back and let them do what they want and you can just keep driving! cant do that with a TT
you can also typiclay make a much tighter turn in a 5er as you can just about jack knife it without really any issues.......tyring to turn in a tight area not out on the road that would be bad in anything....
Old Jul 17, 2008 | 02:02 PM
Medic 66's Avatar
Medic 66
I neglected to think of that aspect but a very good point indeed.
Old Jul 17, 2008 | 02:10 PM
Greywolf's Avatar
Greywolf
It's also a lot easier to wheel a 5 when backing.
You don't have to think about the pivot point as hard - it's AT the rear wheels, not four or more feet farther back.
