Headlight Switch Question
Old Oct 30, 2002 | 02:43 PM
FTE Ken's Avatar
FTE Ken
Old Jan 16, 2003 | 04:39 PM
strider9's Avatar
strider9
Is there a trick I'm missing in changing the headlight switch on my 79 F100 ? No problem in disconnecting the harness from the rear of the existing switch. The problem is getting the old switch out of the dash panel ! Any suggestions will be greatly appreciated !
Old Jan 16, 2003 | 05:07 PM
steve83's Avatar
steve83
[updated:LAST EDITED ON 01-16-03 AT 07:06 PM (EST)]Two options:
1) Press the button on the side of the switch (inside the dash) and pull the **** & shaft out.
2) Use a hook in the notch on the back of the **** to release the **** from the shaft.
Then you just unscrew the sleeve that the shaft went thru to release the switch from the dash.
http://www.cybrrpartspro.com/Chilton%20Images/8576/85766076.gif
(Dennis - Fortunately, there was a smaller version on that site!)
Old Jan 16, 2003 | 05:21 PM
Mil1ion's Avatar
Mil1ion
Just make sure the battery is disconnected and the switch is in the ON position 1st<> THEN Press on the button and Pull it towards you
Steve ! Can you re-size the diagram by half so a person doesn't have to scroll sideways to read the text,Please?
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
