Door Lock Cylinders On Expy
Old Jul 16, 2008 | 12:09 PM
deltasoft's Avatar
deltasoft
Ok guys....here's the story...........as you all know i've had some issues to fix on my wife's expy....little by little it's coming back up!
now i got this issue.....
Since i bought truck, the lock cylinders never match the only key i was given for ignition.......the only way i have been able to open my doors would be through alarm system which i dont want to depend on for this.....
I've called, oreilly-autozone-NAPA-FORD-locksmiths (to repin or rekey lock-they all said wont do it) none of them seem to have the 2 lock cylinders for the front doors with keys that would fit on my vehicle.
Guy at NAPA tells me this is a common issue happening to 97 expy's lock cylinders, some dont always fit on the handle............
ANyhow the replacement cylinders i've bought from them and returned have been way different than one i took out of the door in first place that fits fine......
to shorten the story................
I am unable to find lock cylinders with keys that would fit on my vehicle.....
any ideas? can you point me to another company that sells such that would help me?????
Going crazzy........something so simple and noone has it.........
Thanks for all your help a bunch i know am always taking bandwith space away lol with all my questions but u guys are my book when i get stuck lol!
Old Jul 16, 2008 | 01:51 PM
deltasoft's Avatar
deltasoft
re:
ok guys after doing some research looks like my pick is between sponsors / flebay.....
just letting yall know in case u encountered same issue i did....
Thanks again for your help..hope you all have a good weekend....
Old Jul 16, 2008 | 08:26 PM
alloro's Avatar
alloro
When I got my 97 expedition I thought the same thing...different key for the doors. I thought this because the ignition key would go into the lock but I could not turn it. As it turned out, the ignition key is the correct key for the door locks. The locks were just so full of crud that they were frozen and wouldn't turn. Several repeated soakings with WD-40 eventually loosened them all up and they all now work good. Maybe this is true in your case as well.
Old Jul 16, 2008 | 10:52 PM
deltasoft's Avatar
deltasoft
re:
Hi alloro thanks for your suggestion bro...
I went ahead and just checked and guess what! one of the cylinder locks was for the key! heck only bad thing is i ordered new one's already....but.....i learned something new....
besides that i was able to re-pin the other cylinders i bought to the ignition key!!!!!!! by sanding down pins etc to match key.....
i'll teach you guys i thought it was hard but with logic....was very easy......
thought this might help everyone....
if u want to repin your lock..... u have to take cylinder apart by taking front cap off and back leg off as well , it has small retainer......
I was able to do all of this with a sanding machine / and screw driver...
u have to sand the pins untill is even while having the key you're going to use inside the cylinder....this will allow the cylinder to turn when key is on and when key is off pins will fall out again blocking turning of cylinder.......
Hope this helps yall.....another thing learned! woohoo goodnight all.....
Ford Explorer Tremor Review: Best Explorer Ever
Slideshow: a first-drive review of the 2026 Ford Explorer Tremor, off-road and on!
By Michael S. Palmer | 2026-07-07 13:10:58
10 Cheap Ford Trucks & SUVs That are the Most Fun to Drive!
Slideshow: 10 cheap Ford trucks and SUVs that are the most fun to drive.
By Joe Kucinski | 2026-07-07 10:36:13
5 BEST / 5 WORST Selling Ford Models in 2026 (So Far!)
Slideshow: 5 best and 5 worst selling Ford models in 2026.
By Joe Kucinski | 2026-07-06 16:48:56
10 Times the Ford Super Duty Let Us Down
Slideshow: 10 times the Ford Super Duty let us down.
By Joe Kucinski | 2026-07-01 07:42:10
F-150 Raptor R: The PROS & CONS of Daily Driving a Super Truck
Slideshow: the best and worst parts about daily driving an F-150 Raptor R
By Michael S. Palmer | 2026-07-01 07:35:47
