Aftermarket Products
Sponsored by: Worksport
Westin Nerf Bars do not fit
Old Jul 15, 2008 | 07:43 PM
fordboy_52's Avatar
fordboy_52
kit number 25-1435
model 2000 f150 extended (4 door) short bed.
No holes where they need to be? any one encounter this?
Matt
Old Jul 15, 2008 | 08:22 PM
ReAX's Avatar
ReAX
1435 sounds right.
However, the brackets could be a problem for a first time installer. The instructions are confusing, the pictures aren't very good 3d images.
Lets see, http://www.westinautomotive.com/page...ts/75-0508.pdf
From memory, the stock holes are covered in either gromets or tape (the tape is painted over.) They have to come out so you can set the bolt plate. The front brackets have only two holes, and flange with two holes should sit flush against the body and Z inward toward the frame. The rears have two sets of two holes, each application uses a different set.
Old Jul 15, 2008 | 10:09 PM
fordboy_52's Avatar
fordboy_52
I think i figured it out, but it still doesnt fit. they are off by about an inch and a half. Im almost to the point of re drilling my brackets.......
Matt
Old Jul 16, 2008 | 10:19 PM
ReAX's Avatar
ReAX
I think one set of the brackets can be swapped to get them to fit right. It's been a while since I had this problem, but I had a customer going through the same thing. I got under it and it fit in just a few minutes. Try moving the brackets around.
Old Feb 15, 2009 | 01:13 PM
fordboy_52's Avatar
fordboy_52
for the sake of closer, i ended up torching new holes in the brackets and they worked fine. they are still on the truck and look good.
