CONSTANT HEAT! HELP
Old Jul 24, 2000 | 05:28 PM
masen2001's Avatar
masen2001
CONSTANT HEAT! HELP
The lever that moves the temp. adjustment cable was diconnected when I bought it, I have tried to pull on the cable to get it to move but have had no luck. Once the truck warms up hot air just blows into the truck.......During the hot *** summer no less! Any suggestions?
Old Jul 24, 2000 | 11:42 PM
nitro94's Avatar
nitro94
CONSTANT HEAT! HELP
Some cables stay inside the cab and some go through the firewall to the engine compartment. In either case track down the other end where it hooks up to the blend air door and decide if you need to replace the cable or just tie the door off the other direction for now.
Old Jul 25, 2000 | 10:27 PM
nitro94's Avatar
nitro94
CONSTANT HEAT! HELP
